Main > Main Forum
How do I mount a Coin door light in this door?
PedroSilva:
--- Quote from: eightbit on February 04, 2004, 11:12:25 am ---
--- Quote from: arizonacats on February 04, 2004, 11:08:30 am --- I don't have a picture of mine right now, but I think you can check out an exploded view of one on their web site:
http://www.happcontrols.com/coindoors/40003800_exploded.htm
Turns out they don't show the bulbs mounted there either. :(
It would be great if you or someone else with this style of door could take a pic for me. They show the lightbulb and holder in the exploded diagram but its rotated the wrong way to see where or how it mounts.
Mine is similar ... I'll try to get a picture for you tonight ...
Brad Lee:
Mines got the same mech holders. It uses a little white plastic clip that snaps onto the little raised part
The bulb is a wedge base, so it plugs right into the front ofthe holder, and there are 2 wire terminals coming out the back.
If your coin mechs work, then they have a ground wire. SImply extend that to both of the light bulbs
screaming:
--- Quote from: Brad Lee on February 04, 2004, 11:46:09 am ---If your coin mechs work, then they have a ground wire. SImply extend that to both of the light bulbs
Okay, I'm still learning as I go with all this arcade business, so please excuse the ignorance.
Can I really ground my 12v bulbs with my I-PAC (which supposedly only outputs 5v)?
/Steve
Ken Layton:
Yes, that is a late model Happ Controls door. They sell replacement (white) wedge base lamp sockets for it.
SirPeale:
--- Quote from: screaming on February 04, 2004, 12:28:44 pm ---
Run it from your power supply.
