Author Topic: Teknoparrot Only (Sega Racing Classic) fix nvidia glitches  (Read 29447 times)
Nuexzz
« on: April 15, 2018, 09:40:20 am »
Here we have a "fix glitches of Nvidia graphics"
you have to have the game in the directory.
C: \ Sega Racing Classic \ d1a.exe
https://drive.google.com/file/d/1hgM4p6-wfKSXLWMxbdrBY0wJasW482oD/edit
unzip Sega R.C fix Nvidia and run the exe
then open your teknoparrot and magic !
good is awesome that I think of so many topics in the forums with teknoparrot (countless number of pages) so I'm sorry but I have to open a new thread just for sega racing classic,
I sincerely see this version much more stable than Daytona Usa (m2emulator)
I have many doubts with the charger, but I'm going to start with the 2D graphics.
Has someone already found an "adjustment" solution?
this happens when you modify the original resolution from the binary.
« Last Edit: May 09, 2018, 03:50:18 pm by Nuexzz »
Nuexzz
Re: Teknoparrot Only (Sega Racing Classic)
« Reply #1 on: April 15, 2018, 11:43:05 pm »
modifying the resolution from the d1a.exe
a little information :blah:
You can create a graphical user interface and configure these things easily. (No, I do not know if someone will have time to play with things like that)
I do not think so, at least I for a while
[offset= 002e22fe]
640x480
80 02 E0 01
704x480
C0 02 E0 01
720x480
D0 02 E0 01
800x600
20 03 58 02
852x480
54 03 E0 01
1024x768
00 04 00 03
1080x720
38 04 00 03
1280x720
00 04 D0 02
1280x800
00 05 20 03
1280x1024
00 05 00 04
1360x850
50 05 52 03
1366x768
56 05 00 03
1440x900
A0 05 84 03
1600x1200
40 06 B0 04
1680x1050
90 06 1A 04
1920x1080
80 07 38 04
1920x1200
80 07 B0 04
« Last Edit: April 15, 2018, 11:59:15 pm by Nuexzz »
buttersoft
  • Last login:Today at 12:17:38 am
  • Is running at 15kHz
« Reply #2 on: April 16, 2018, 02:21:36 am »
I was actually thinking of giving SRC a go. Does your original post imply you need to hack the .exe to change the resolution?
nugarp
  • Last login:February 22, 2026, 08:15:13 pm
« Reply #3 on: April 16, 2018, 03:14:56 am »
Yes, although the screenshot seems to indicate that he's having the shader issues too (pink road, etc.).
trick72
  • Last login:August 29, 2025, 04:00:45 am
« Reply #4 on: April 16, 2018, 11:02:55 am »
Yes, shader issue when playing with Nvidea card is also my largest issue with this game... I haven't put it on my cab for that reason
nugarp
« Reply #5 on: April 16, 2018, 11:05:06 pm »
Thats why I'm sticking to Daytona 3!
Sent from my SM-G950U using Tapatalk
« Last Edit: May 06, 2018, 08:10:17 pm by nugarp »
buttersoft
« Reply #6 on: April 17, 2018, 01:50:49 am »
Nugarp, is it possible to adjust the res of Daytona 3? And is it possible to get connect two cabs via LAN?
nugarp
« Reply #7 on: April 17, 2018, 04:09:36 am »
Res, I don't remember. It's been too long since I set it up. Mine runs at 1080p I believe. Multiple cabs, yes.
1. Your network must be 192.168.1.x
2. Your machine IP addresses' X value must be low (somewhere between 1-8 or 1-10 or something)
3. Edit \ShellData\ShellData.ini and set CabinetID and NumCabinets under Network.
4. Edit \ShellData\GameSettings.ini and set TOTAL CABINETS to # of machines.
5. Edit \GameData\Game.ini and set CabinetDomain to 192.168.1, and set CabinetBaseAddr to the "X" from step 2 (from your machine's IP)
It may require fewer steps but those are the 5 I had used to set it up.
nugarp
« Reply #8 on: April 17, 2018, 04:11:05 am »
6. Each machine MUST have a webcam. I used some fake images I made along with SplitCam software that runs at startup. It will automatically use Splitcam when the games start. I don't use a physical webcam with the games.
It may require fewer steps but those are the 6 I had used to set it up.
trick72
« Reply #9 on: April 17, 2018, 04:22:05 am »
I can only get Daytona 3 to run windowed. Fullscreen it runs only at half speed. When using "borderlessfullscreen" it works, but also with bad performance... a lot of jerky framerates on numerous locations... like it does not perform very well (I have a nvidea 980ti so it should be more then enough). Network works fine as long as you have a webcam or install webcam software like fakecam.
Friko
  • Last login:June 11, 2020, 11:57:00 am
« Reply #10 on: April 17, 2018, 07:09:04 am »
It's your graphics card
Nuexzz
Re: Teknoparrot Only (Sega Racing Classic) Fix Nvidia
« Reply #11 on: May 06, 2018, 08:09:04 pm »
updated first entry
nugarp
« Reply #12 on: May 06, 2018, 08:11:37 pm »
updated first entry
I tested this and it works great. Great work Nuexzz & Boomslang!
segaturbo
  • Last login:June 04, 2023, 12:31:01 pm
  • SEGA FOREVER
Re: Teknoparrot Only (Sega Racing Classic) fix nvidia glitches
« Reply #13 on: May 07, 2018, 11:38:58 am »
same here works perfect !!!!!!
 :cheers: for the patch
isamu
  • Last login:February 19, 2026, 01:09:24 pm
« Reply #14 on: January 28, 2019, 07:34:38 pm »
The recent versions of TeknoParrot seems to have broken this fix. Still getting red lines all over the track even with it enabled. Any ideas?
Nuexzz
« Reply #15 on: January 28, 2019, 09:51:40 pm »
I personally did not update my teknoparrot  :dunno, I went back to my old and dear m2emulator :)
isamu
« Reply #16 on: January 28, 2019, 11:15:15 pm »
Hi Nuexzz hope you're doing well my good friend. You may disregard my last comment. Turns out I didn't activate the app in the proper order, but I got it working now so all is good :)
But......the reason I would rather play SRC over Daytona USA, is because I've found a way to replace the music files in the folder containing the music for the game. It's a relatively simple affair. However, this is not possible with the original Daytona USA rom file for use with Model 2 emulator. I do remember however, that a while back, you made some kind of way to alter the music and sound within Daytona USA. Can you remember what you did Nuexzz? Because I desperately want a way to mute or eliminate the music from the original Daytona USA game, so I can play my own soundtrack. Nuexzz can you please find a way to accomplish this task my good amigo?
Nuexzz
« Reply #17 on: January 31, 2019, 11:01:12 am »
I was looking for the address of memory and I can not find it. I will let you know if I have news
isamu
« Reply #18 on: January 31, 2019, 06:15:33 pm »
Yes please do! I want this **BADLY** !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
AMG KC
  • Last login:June 29, 2022, 05:33:52 am
« Reply #19 on: April 24, 2019, 12:23:13 am »
How do i get the music from Daytona USA onto Sega Racing Classic?
gstav
  • Last login:December 19, 2025, 05:53:11 am
« Reply #20 on: September 28, 2019, 12:09:51 pm »
+1 for the music, but even more
remove the pink stripes on the road. Any news on it?  :cheers:
"One coin to rule em' all"
Nuexzz
« Reply #21 on: October 05, 2019, 02:08:58 am »
well this solution is actually portable and I want to publish some aggregates that I have discovered personally (as Daytona USA ++) although I see that it is a very stable game compared to m2emulator ... I still think "people are NOT interested in this game?
isamu
« Reply #22 on: June 10, 2021, 07:55:01 pm »
Hello Nuezxx how are you my freind?  :burgerking:
Bro, is there any way you can please create an ini file or something, that allows us to use the nvidia fix app in a different directory besides C? I'm running out of space on my main C drive and cannot store the game on there any longer. I have it installed on my D drive instead, and would like to be able to use the nvidia fix there. Please help.
On a side note, it's been ages since SRC was supported in TP. Has there been any progress or plans to fix the graphic glitches without having to use Neuxzz's app? Or is there a work around that I'm not aware of?
Pstylz
  • Last login:February 20, 2026, 12:53:08 am
  • 4Player Arcade Racer - WIP
« Reply #23 on: May 22, 2023, 09:29:57 am »
[offset= 002e22fe]
640x480
80 02 E0 01
704x480
C0 02 E0 01
720x480
D0 02 E0 01
800x600
20 03 58 02
852x480
54 03 E0 01
1024x768
00 04 00 03
1080x720
38 04 00 03
1280x720
00 04 D0 02
1280x800
00 05 20 03
1280x1024
00 05 00 04
1360x850
50 05 52 03
1366x768
56 05 00 03
1440x900
A0 05 84 03
1600x1200
40 06 B0 04
1680x1050
90 06 1A 04
1920x1080
80 07 38 04
1920x1200
80 07 B0 04
Hi Nuexzz,
Any chance you can elaborate here please?
I've tried using a Hex editor (Free Hex Editor Neo) to change the values but with little success.... when I go to offset: 002e22fe I'm not sure where to add "80 07 38 04" for 1920 x 1080 resolution?
Thanks in advance!
« Last Edit: May 22, 2023, 09:31:46 am by Pstylz »
