Main > Main Forum
J-Stick issue
Pages: << < (2/3) > >>
Wade:
I had this problem initially, but then I grabbed the botton end of the shaft with some pliers, and twisted the knob on real tight with my hand.  They haven't worked loose ever since!
Wade
NoOne=NBA=:
You don't get to stink up the house that way though.  ;D
I tend to follow the redneck way of repairing things:
1) If it moves, and it ain't 'spose to--use Duck Tape or Epoxy.
2) If it don't move, and it's 'spose to--git out the WD-40.
2a) If it still don't move--git a bigger hammer.
It WILL move--trust me.
canardo:
as stated get some pliers and hold the metal stalk and then do it up worked for me
IG-88:
--- Quote from: str1der on February 03, 2004, 03:17:54 pm ---Thanks. I assume I can get that at the harware store?
I think I've even seen it at Wal-Mart
rampy:
Doesn't the j-stick shaft have a groove at the bottom that is perfect for a flat head screw driver to help you hold the shaft steady whilst you crank down the ball?
rampy
Go to full version
