Arcade Collecting > Miscellaneous Arcade Talk
Warzaid RTC
badsof:
Hi everybody,
I have the same problem. :(
I have an Arcade cab Warzaid 4 players (Europe version) AAD:B, my 2 RTC are bad. I have progrmed new RTC with source MAME files but its not WARZAID i found only World Combat (AAD:B) but World Combat is an Asian version not EU. when i boot the cab after Rom "OK", RTC OK, Network checking i have an error message with Hardware error or if i puch test button at the message Network cheking the game boot!
Problem is the bad files from source Mame, i search if its possible to found Warzaid (EU evrsion AAD:B)
Please help :'(
PL1:
--- Quote from: badsof on December 12, 2020, 02:43:42 am ---i found only World Combat (AAD:B) but World Combat is an Asian version not EU.
The first letter of the three letter code usually describes the region or country.
A for Asia -- World Combat (ver AAD:B) [wcombat.zip]
or World Combat (ver AAD:B, alt) [wcombatb.zip]
J for Japan -- World Combat (ver JAA) [wcombatj.zip]
K for Korea -- World Combat (ver KBC:B) [wcombatk.zip]
U for U.S. -- World Combat / Warzaid (ver UCD:B) [wcombatu.zip]
Those are the only five versions mentioned in the current MAME "Viper" driver source code. (lines 3099 - 3103)
https://github.com/mamedev/mame/blob/e13d0d433e70b6f7797f35ba770c4e8e83edf07c/src/mame/drivers/viper.cpp
Doesn't look like there are any European (E for Europe) or Australian (O for Oceania) dumps. :dunno
If the correct file isn't in wcombatu.zip, wcombat.zip, or wcombatb.zip, you might need to track down and dump the RTC from a boardset that matches yours.
badsof:
Hi
thank you for the clarification.
It's very complicated because when I put UCD RTC files I have only single game (2 players), no possible to link but work very well and if I put AAD:B RTC files, link possible to use 4 players, but I can play only if I puch test button at the "network check" message.
My Flash card is C22D02 you don't know If there will be a solution other than finding a functional (EU) RTC to copy it?
Navigation
[0] Message Index
[*] Previous page
Go to full version
