Main > Software Forum
[4/1/2024] -Pi4/5 Support Incoming -Major League SkeeBall -- SkeeBall Controller
Pages: << < (54/59) > >>
rick_bungle:
Maybe a dumb question, but is there a place to edit the text?  As an example I noticed it says "2rd" place.  I don't know anything about programming but I can edit config and XML files!  I poked around but didn't find anything.  I saw it was mentioned in a post from 2021.
nipsmg:
--- Quote from: rick_bungle on March 26, 2024, 10:09:55 pm ---Maybe a dumb question, but is there a place to edit the text?  As an example I noticed it says "2rd" place.  I don't know anything about programming but I can edit config and XML files!  I poked around but didn't find anything.  I saw it was mentioned in a post from 2021.
that's a bug.  I'll have to fix that this spring when I get a new final release out.
nipsmg:
Got my Pi5 in and had to at least get a POC running.  Still have a ton of billing work to do so I wont' have a ton of time to work on it, but I'd like to get to it this spring.
Jstgilstrap:
im loving the software but Im having a issue. For some reason the 40 and 50 will double hit. I dont think its the switch double hitting since I can use my fingers and it still does it. I have tired different switches too with the same thing. Also if I have one ball left and hit the 40 or 50 it will make the software go all crazy. The balls played will start  counting up. I will get a video of it and post it.
Not to sure what to do to fix this issue.
Jstgilstrap:
Here is a video of what it is doing
https://photos.app.goo.gl/WERNbARvNvRPsRQT7
Go to full version
