Main > Monitor/Video Forum
B&K 467 rejuvenator service information available
Pages: << < (4/8) > >>
Ken Layton:
Sorry, I don't know what the values are for restore/clean balance settings.
I can post manuals.
Corey986:
 So I just recapped my new to me BK467, according to google you guys here seem to have the most information on them.
The service manual isn't very clear on the tracking range calibration.
After hooking up the resistor and warming the unit up, it says to putthe 467 into test mode, adjust the G2 red control till it reads full scale on the meter. I assume that means when it's at 2.0 (all the way to the right)?
Then it says while pressing the tracking button and adjust R23 until it reads the minimum setting. Does this mean 0 on the meter or at the "set tracking mark". I can't adjust R23 any lower than .2 on the meter so I'm hoping it's not supposed to be set to 0.
Any help is appreciated.
Thanks,
Corey
Sent from my iPad using Tapatalk
Nephasth:
NVM...
Mr. Peabody:
By what I remember reading, I had the idea you plugged it in the neck and let it do its thing......
Corey986:
--- Quote from: Mr. Peabody on May 16, 2019, 05:53:06 pm ---By what I remember reading, I had the idea you plugged it in the neck and let it do its thing......
The unit needs to be calibrated after any major work like replacing caps.
Then you can simply plug it into the neck, check the guns, clean them or rejuvenate.
Go to full version
