Author Topic: I need fix the "non-power-of-two textures" issue with ATI 9200 and Groovymame  (Read 3383 times)
metwar
  • Last login:November 06, 2017, 11:04:48 am
Hello! I'm spanish, disculp my English, please. Congratulations to all the people, I'm pleased to talking here.
I have an Athlon XP 2400+ with a modded avga radeon 9200 for 15kHz, and crt emudriver under windows XP.
When i launch groovymame 0.189 I receive this message: your card not fully supporting "non-power-of-two textures"... and some more about direct3d9 etc...
I'll be very greatful if some one help to me. Thanks.
DaredevilDave
  • Last login:October 12, 2018, 01:14:45 am
  • Yes, I really am still working on it!
Hello!
A power of two texture refers to texture images used in the game or program being run. Examples of this would be image sizes of 16x16 pixels, 32x32, 64x64, 128x128, 256x256.....2048x2048....
Apparently whatever you are trying to run contains textures that are not of these sizes. Non-power of two would be 1020x960, 129x129, 53x195, etc.
Your video card is very old (2003 I think) so it sounds like it can't handle these and doesn't support direct3d9.
I think you need a newer video card. Any cheap modern card will do.
« Last Edit: October 18, 2017, 09:36:03 pm by DaredevilDave »
"Computer Space" (1st coin-op game ever) for MAME Front Ends Available Now!
http://forum.arcadecontrols.com/index.php/topic,155041.0.html
My Custom Motorcycle Cabinet Build For Custom Game (Daredevil Dave):
http://forum.arcadecontrols.com/index.php/topic,151106.0.html
metwar
Thanks, very much. But I'd readed that if change this in the source files and compile, could fix this issue. I belive that Calamity said this in another post, I'll check it. Of course, You have the truth: my graphic card is VERY OLD, but it's an ArcadeVGA 9200 clone and it's good for many non 3D games. Thanks.
Robbbert
  • Last login:Today at 04:40:45 am
If you are able to compile you can try this:
Open src\osd\modules\render\drawd3d.cpp
Have a look at lines starting at around 1095 you will see 2 tests for non power of two textures, comment it all out.
Compile and see what happens. It fixed it on my 2011 embedded video, but of course if your card is very old it may simply expose other issues with your hardware.
Good luck.
metwar
Thanks. But I don't know how complile groovymame. I need an updated tutorial. I think that your solution could be posible.
metwar
Josef1975
  • Last login:July 09, 2021, 06:01:15 am
    • MY ARCADE CABINET
Compiled version ready to use from bandito :
https://b4nd1t0.blogspot.it/2017/10/mame0190.html?m=1
Thanks robbert for suggestion, if someone Can verify if It works.. I'll try in the weekend in my cab with my old ATI 9250
« Last Edit: November 01, 2017, 07:12:29 am by Josef1975 »
metwar
Downloading for testing. Thanks
metwar
I'm reading your web about to conect VGA to SCART, and I'm surprised. Very good information. Thank you very much.
Jasper27
  • Last login:January 12, 2021, 09:40:42 am
I can verify it works fine with my arcadevga 9250/128  In fact its great.  Don't have to use VMMaker or avres and there is zero tearing.  Amazing software this switchres.  Would someone be so kind as to compile a 32bit mame 0226 version for windows xp?
