Author Topic: Cuphead dedicated cab (feasibility study stage)  (Read 42518 times)
Ian
  • Last login:February 27, 2026, 11:36:05 pm
Re: Cuphead dedicated cab (feasibility study stage)
« Reply #80 on: October 20, 2017, 01:09:51 pm »
« Reply #81 on: October 20, 2017, 01:55:49 pm »
Look at this!
This one. Right here.^^^^
Looks like side art and isn’t a ---smurfy--- collage jumble.
« Last Edit: October 20, 2017, 02:08:27 pm by yotsuya »
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
« Reply #82 on: October 20, 2017, 02:12:01 pm »
Another Cuphead cabinet video was just posted at the The CRT Collective Facebook page.
 Not trying to pile on- but Yes, that seems to be tossed together rather hastily with leftover parts.
Not quite bad enough for here though..
http://www.wickedretarded.com/~crapmame/
« Reply #83 on: October 20, 2017, 02:55:19 pm »
Look at this!
and its easy enough to get rid of those annoying watermarks too.
  • Last login:March 17, 2026, 10:06:06 am
« Reply #84 on: October 21, 2017, 02:29:02 pm »
How many buttons do you need for each player? I've heard you need a button for the mid-air jump in addition to the jump, sounds stupid if true. Would it be possible to map those two to the same button?  :cheers:
Ian
« Reply #85 on: October 21, 2017, 02:51:50 pm »
There is Shoot, Jump, Dash, Weapon select.
twistedsymphony
  • Last login:February 03, 2024, 11:13:51 pm
  • Play stupid games... win stupid prizes.
    • solid-orange.com
    • CollectorsEdition.org
« Reply #86 on: October 26, 2017, 11:13:00 pm »
have you got anywhere with that iPAC?
I'm trying to get CupHead setup on my cab with iPAC but there are a few problems
mainly, that CupHead is one of those games that requires separate devices per player. So player 1 can use a keyboard but player 2 must use a joystick.
Someone else also mentioned the hard mapping of the Z key for world interactions, and that's true (and annoying) but it's also true that you need the enter key for menu navigation and the escape key to back out of menus.
I thought I'd solve this with Vjoy. just make profiles to map the keyboard keys to virtual joysticks. while that solves the 2-player issue, it doesn't solve the menu navigation and Z-key issues as for whatever reason cuphead ONLY accept joystick inputs from a 360 controller for those things... normal joysticks (and thus vjoy) aren't supported in the menu  and over-world interactions.
people on the steam forum are using x360ce to get around these problems with normal joysticks... I haven't figured out how to integrate that into my setup yet... for you you might be better off just pad hacking some 360 controllers to avoid the ridiculous joystick emulation mess that is trying to use modern pc games with a keyboard encoder.
  • Last login:March 14, 2026, 08:11:32 pm
« Reply #87 on: October 27, 2017, 10:25:34 am »
Keyboard encoders have been obsolete for using joysticks on modern PC games and replaced by the Xbox 360 controller for several years now.
Stop screwing around with your ipac.
ballboff
  • Last login:July 22, 2024, 02:25:17 am
« Reply #88 on: October 27, 2017, 12:33:55 pm »
I like this one...
Sent from my SM-A510F using Tapatalk
« Reply #89 on: December 08, 2017, 02:52:44 pm »
Szabo's Arcades offers a Cuphead art kit now:
https://szabosarcades.com/products/cup-head-art-set
DeL
« Reply #90 on: December 08, 2017, 09:20:49 pm »
DeL
over priced and aesthetically displeasing.
Ian
« Reply #91 on: December 09, 2017, 02:17:58 am »
I think he gave up on this project anyway.
Paradroid
    • SCART Hunter
« Reply #92 on: December 09, 2017, 02:27:37 am »
Nah... was just really bummed that my fist CRT turned out to be an expensive dud and have also had to travel quick a bit for work recently.
Still have the project in mind though and picked up a second 16:9 CRT on Wednesday. Sony Wega with component input.
I have a Kramer FC-14 transcoder that I plan house with this TV. No idea if the TV can do 480p yet (would prefer not to be interlaced) but I'll find out when I get a chance to test.
Also have been working to clear my shed of other projects...
Sent from my SM-G955F using Tapatalk
Paradroid
    • SCART Hunter
« Reply #93 on: December 09, 2017, 02:35:45 am »
Agree.
Have trawled through all the photos on Coinop Warehouse's FB page and have definitely warmed to the yellow vibe (mimicking the classics) with athe idea to have a simple artwork overlay.
As stated in the beginning, the CRT is the start point for me so the design will start once that's locked in.
« Reply #94 on: December 12, 2017, 12:58:37 pm »
As a last resort, why not go with a 4:3 CRT?  It looks pretty fantastic on my 27" Multisync monitor on my MAME cab.  I'm actually glad that the developers didn't forget about us 4:3 guys.
DeL
Paradroid
    • SCART Hunter
« Reply #95 on: December 12, 2017, 01:54:23 pm »
Yes, there's always that. Would certainly make the cabinet decision easier (more conventional).
I have two 29 inch Philips Matchline III CRTs with VGA input. Both have an excellent picture quality.
What did you mean by that? There's still no actual 4:3 mode, is there?
bogaboy
  • Last login:May 26, 2018, 12:33:05 pm
« Reply #96 on: February 26, 2018, 07:27:50 pm »
Hello, Paradroid!
First time poster here. About a month ago I decided to make a Cuphead arcade machine and I started researching the hobby. I'm in the process of the build right now and stumbled upon this thread while googling to see if anyone else had the same idea. Apparently I'm less creative than I thought!
I wanted to check with you to see if this project is dead or if you're still working on it or maybe you've finished?
I created some artwork of my own for the control panel and I'm pretty proud of how it turned out. I'm not ready to share it publicly until the project is done, but if you're still in need of artwork I don't mind sending it to you in an email. Of course, you might hate it. Just figured it'd be nice of me to offer, especially since you had the idea first. Plus I'd love to hear how the project came out!
- Bogaboy
