Author Topic: Starting first build!  (Read 2908 times)
Erzak
  • Last login:August 23, 2021, 03:47:45 pm
  • First cabinet complete, now about that software...
« on: July 16, 2017, 10:31:23 pm »
Started my first build this weekend, using the "Cabinet Plans 2" from www.arcadecab.com as a starting point and modifying things to fit a larger LCD monitor, and possibly a larger control panel.  Got the first side cut out today and after I clean up a few lines, will transfer the outline to a 2nd sheet of plywood and cut it as well, AFTER I practice using my new router on some scrap wood...
Question reg. T-molding slotting: do most folks run T-mold on all edges, back of the cabinet included?  I am guessing it would look nicer to have T-molding all the way around?
Thanks,
Eric
Drnick
  • Last login:May 06, 2023, 01:19:48 pm
  • Plodding Through Life
Re: Starting first build!
« Reply #1 on: July 17, 2017, 01:24:08 pm »
Yes :) I do not remember seeing one that doesn't have T-molding all the way round. Maybe if it was a small machine hanging on a wall you wouldn't want it round the back. Other than that wrap it all the way and then the cut can be located at the back or at the bottom where nobody will see it.
Erzak
« Reply #2 on: November 17, 2017, 10:25:18 am »
Figured I should post a picture of the final result.  Thanks to everyone here and elsewhere who provided building tips and such.  There are a number of small flaws that I see but nothing that anyone else has noticed.  Still working to get everything setup as far as software goes, but I know that will be an ongoing thing.  MAME is running fine, using F.E.E.L. for the time being, since it's using an old P4 running XP.  The PC may change sooner than thought, as it's started having some issues in the last few days.
  • Last login:March 21, 2024, 08:20:28 am
« Reply #3 on: November 17, 2017, 02:24:58 pm »
Real nice wood finish.  Looks great without side art!!
EMDB
  • Project RetroCade
« Reply #4 on: November 17, 2017, 05:11:18 pm »
It would have been so much nicer if he had chosen matching (and less different) button colors  :dizzy:
« Reply #5 on: November 17, 2017, 05:17:17 pm »
I could nitpick about that. and the generic marquee too, but that is easy stuff to change up at a later point. The cab looks solid.
Erzak
« Reply #6 on: November 17, 2017, 06:17:22 pm »
Well, to each their own.  I did that on purpose, different color for each group of controls.  Though I need one more yellow button so that the Asteroids group are all the same color.
« Reply #7 on: November 17, 2017, 06:52:53 pm »
I totally think the player buttons being different colors looks fine. :cheers:
IMHO, the admin buttons look a little frantic in the back. Green, orange, purple, white, etc in the back is a bit too much going on. Buttons are a couple bucks each, not hard to adjust if need be. If button colors is the gripe from the gallery, then you did really good.   8)
My recommendation, would be go all black buttons in the back, and get some vinyl decals for the button tops to signify what they do. Will be classy.
http://forum.arcadecontrols.com/index.php/topic,130477.msg1335286.html#msg1335286
