Author Topic: CRT_emudriver 2.0 - Error Driver Installation Failed 103 - Radeon HD 6870  (Read 4410 times)
kimikat
  • Last login:June 12, 2018, 09:09:38 am
Hi Everyone  :)
I am currently building a pc for arcade emulation purpose using a computer that was given to me :D
Graphic card is a Radeon HD 6870 and OS is Windows 7 64.
I have downloaded CRT Emudrivrer from the following link (http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=295) and upon reboot into test mode I get an error message claiming "instalation failed 103 no data available".
I have been searching this error on google qnd in this forum with limited success as such i am taking the liberty to create this new topic.
Can anyone advise if aditional files are needed ouside of the normal package from the "geedorah" website ?
I qpologise in advance if this topic has alrady been covered somewhere else.
If this is the case please point me toward the relevant post :)
Oh and on a side note english is not my primary language so apologies if my post is not clear enough :(
Kind regards.
Kimikat.
  • Last login:April 10, 2024, 02:02:31 pm
There are three different packages in that link, which one did you use?
kimikat
Hi Calamity :)
Just came back to say that the issue was caused by the fact that the windows version i installed was not x64 but x86....
The disc i used to install my system was wrongly labeled....
I noticed it almost by accident when checking the system status.
I tried a x64 reinstall and i am fine now (I am actually typing this with the internet window displayed on my CRT screen)
I now need to understand how to properly setup groovymame to display the right resolution at the right refresh rate automaticaly for each game but that is another topic :D
So to make it short should anyone get this error message in the future, check your windows version.
God i feel stupid now.
Thank you for taking the time to look at my question :)
Kimikat
Spiderman9370
  • Last login:August 31, 2018, 11:07:22 pm
Hello all ~    :cheers:
I am experiencing a similar problem with a failed driver installation, so I figured I would post my problem to this thread.
The message reads:  "Error: The driver installation failed: 103 No more data is available."
I am attempting to download CRT Emudriver & CRT Tools 2.0 beta 10 (Crimson 16.2.1 for GCN* cards) for Windows 7/8/10 64-bits.  I am loading it on a brand new HP desktop PC.
Operating system:  Windows 10 Home 64-bit
Processor:  AMD A10-9700 RADEON R7
The Eiusdemmodi site lists AMD Radeon R7 200 and R7 300 as compatible with CRT Emudriver & CRT Tools 2.0 beta 10.
I have disabled Secure Boot on the PC and am in test mode.  When I launch setup, the top of the window says "CRT Emudriver 2.0 beta 9" (not beta 10).  I am not sure that has anything to do with the problem but thought I would mention it.  The setup window lists my AMD Radeon R7 Graphics device as a compatible device.  The box is already checked.  When I hit the "Install driver" button to begin the install, an installation box pops up, and the installation proceeds for about a millisecond until another box appears with the message "Error: The driver installation failed: 103 No more data is available."
Does anyone have any suggestions for how to get past this error, or an explanation for what is preventing the install?  Any help would be appreciated.
