Main > Everything Else
Anyone have experience repairing contact pads on controllers?
<< < (3/3)
dkersten:
Any chance that "oil" is dielectric grease used to prevent the contacts from corrosion?
RandyT:
--- Quote from: dkersten on July 05, 2017, 10:27:57 am ---Any chance that "oil" is dielectric grease used to prevent the contacts from corrosion?
Virtually none.  My theory is, being that the membranes are silicone, oils from your skin (or the french fries you were eating before you picked up the remote  :lol) transfer to the buttons, and over time, creep inside the units simply from gravity.
The other possibility is that the oils in the silicone leech out due to age.  But that's usually a clean, clear fluid.  The stuff I found in my friend's remotes was neither.  It looked more like new motor oil.
pbj:
What did it taste like?
RandyT:
--- Quote from: pbj on July 05, 2017, 10:40:13 am ---What did it taste like?
If I'd have known you wanted to eat it, I'd have saved it for you.
ChadTower:
Randy's remote be like...
Navigation
Message Index
Previous page
Go to full version
