Main > Consoles
Got me a Vectrex.
<< < (10/25) > >>
chopperthedog:
--- Quote from: opt2not on June 22, 2017, 01:55:13 pm ---Did he happen to sell all of them? (I don't have an Atari age account)
Same, I've read a ton on AA, just never felt the need to create an account and post there. I sent you a pm.
good day.
burn_654:
Really like the joystick, I'd be interested in building one!
Do you have a part no. for the joystick? From what I understand vectrex joystick wiring is pin to pin, no encoder is needed, correct?
I have some old analog tandy/ch mini computer analog sticks in the parts bins, I wonder if they could be suitable...would probably have to dial in different resistors too.
Well done!
chopperthedog:
The VecMulti from Richard H. is a neat piece of hardware. I just didn't like how it was packaged in the 3d printed case and how it just kind hung there in the cart slot with the edge connector being the only support.
The SDcard reader was soldered to the underside of the main pcb with a straight header. After some thinking and planning I came up with a way to mount the SD reader to the top of the main pcb and offset the SD placement so that I could use a stanrdard cartridge shell.
No modifications were needed to the scramble cartridge shell, I'll find a repro shell to use in the future. The 2 plastic posts in the bottom shell are narrower than the width of the SD reader pcb, so it made sense to figure out a way to top mount it. The SDcard has been set up and sorted the way I want and I haven't had the need to pull it for a couple weeks. It's only 1 screw to get access anyway.
good day.
chopperthedog:
mmmmmmmm, Nothing like the smell of fresh Sanwa 24mm buttons in the morning.
good day.
nitrogen_widget:
when you scroll down the page your pic of the buttons in the box creates an optical delusion of it getting bigger.
totally made my eyes go  :dizzy: LOL!
Navigation
Message Index
Next page
Previous page
Go to full version
