Lightguns Arcade1Up --- Bug Reports --- Site News
Poll
What default port assignments would you prefer for Mapper?
Set the ports to blank.  That will prompt users to either assign ports or load a mapping (.DAT) file.
1 (11.1%)
Make mapping (.DAT) files and pinout images for the Arduino boards.
0 (0%)
Both of the above.
5 (55.6%)
Leave the current defaults.
0 (0%)
Doesn't matter.  It's easy to load a .DAT file and/or reassign ports.
3 (33.3%)
Total Members Voted: 9
Author Topic: KADE miniArcade 2.0 beta release  (Read 17974 times)
  • Last login:Today at 08:08:06 pm
Re: KADE miniArcade 2.0 beta release
« Reply #80 on: February 10, 2019, 10:35:53 pm »
Which of the two DFU bootloaders is correct for the Mattairtech board: the Atmel DFU, or the non-Atmel DFU?
The non-Atmel DFU is the better choice.
Either one will work, but the Atmel DFU bootloader requires a pullup resistor.  (See step 3 here.)
xefned
  • Last login:Yesterday at 03:44:34 pm
  • Unearthing ancient threads is my special skill.
    • Matthew's projects
« Reply #81 on: February 16, 2019, 01:35:12 pm »
Haha, thank you for clarifying!
I was just about to post something I found in another thread: "Scott PL1 says Atmel." for other people looking for an answer. But I will go NON-Atmel now, since I wouldn't know where to put that pullup resistor anyway.  THANK YOU!!
I bought 2 minimus boards for around $4 each a few years ago.  Built raspberry pi's and gave them away to friends.
 Last week I decided I could use a few more and discovered the word's supply of cheap minimus boards is now long gone.  Got research to do...  :blah:
Searching for Zwackery, not because it's rare, because it's fun.
« Reply #82 on: February 16, 2019, 04:46:04 pm »
The next post after that is Bruno correcting my imperfect advice by pointing out that, "Non-atmel DFU bootloader is preferable over Atmel's.", immediately followed by me agreeing that non-Atmel DFU is the better option.    :lol
The OP of that thread was updated with that info several years ago.
- Over 5 years ago when Jon coded the KADESTICK firmware, he recommended getting the Atmel DFU firmware that requires a pullup resistor to keep the board from going into programming mode when power is applied.
- About 2 years ago when Bruno coded the miniArcade 2.0 loader program, he found a way to make it work with the non-Atmel DFU firmware that does not need a pullup resistor.
From the OP of the "KADE-compatible AVR vendors reference list" thread mentioned above.
    miniArcade/microArcade
Keyboard, gamepad, and optical (spinner/trackball) firmwares available in KADE Loader.
atmega32u2 (or at90usb162)
Other vendors:
BYOAC member MaxRod has some for sale.  PM him for details.
It has been a few months since MaxRod logged in, but he's your best bet for getting Minimus AVRs.   :cheers:
xefned
« Reply #83 on: February 16, 2019, 09:16:52 pm »
I spent a giant chunk of my afternoon catching up on what you've all be working on over the last 6 years.  :applaud:
I'm only now fully appreciating how simple my experience was with the Minimus and the 1.0 version of KADE. It's since gone on to support several home console controllers and does worlds more than my highly simplistic original use: 1 Sanwa joystick and 3 buttons to play games in RetroPie. Truth is, that's still all I really care about, and if I'm real with myself, it was the joy of having an inexpensive and easy-to-setup joystick encoder that attracted me most to the project. Ordering a MattairTech board with shipping gets into the price territory of a Mini-Pac from Ultimarc or a KeyWiz40ECO from GGG which are preprogrammed. Overall, just feeling grateful that I got to participate in the KADE experience and build a couple game controllers for friends and relatives.  :cheers:
I see you and other contributors (Jimmer, Locke141, ed12) nearly got the Pro Micro / Leonardo to work. That would've been a breakthrough for a simple, non-proprietary arcade encoder. For now, I'll probably just hit up Andy for another Mini-PAC and get to wiring.
But there is a glimmer of hope for the future:
  1.) The Pro Micro seems to be built to be used as a HID. (Sparkfun 2012 "Intermediate" programming tutorial - way over my head.)
  2.) This guy, first-time poster gschade got a Leonardo working fairly easily.
All of this is way beyond me. I only know how to hook things up and solder.  :notworthy:
« Reply #84 on: February 16, 2019, 11:17:31 pm »
Thanks.  It has been a fun journey.   ;D
There is a bit more of a learning curve for v2.0, but a Sanwa joystick, three player buttons, and (two?) admin buttons setup is really easy to do.
You don't need the MattairTech board for those nine inputs.
A $5 Arduino Pro Micro from e-bay has plenty of inputs.   ;D
There's no nearly about it -- miniArcade 2.0 works with the Pro Micro.
http://forum.arcadecontrols.com/index.php/topic,154126.msg1663852.html#msg1663852
See pages 13 and 14 of the KADE miniArcade 2.0 User Guide for detailed directions.
Have you looked through the User Guide?
It details step-by-step how to do *everything*.
« Last Edit: February 16, 2019, 11:20:50 pm by PL1 »
xefned
« Reply #85 on: February 17, 2019, 12:29:14 pm »
OMG - so excited!!! Simple KADE lives on!
I had hit upon a couple attempts that dead-ended around Feb. 2018, without seeing the success stories that happened after that. My brain was just getting frazzled.  :dizzy:
The instructions look quite do-able. I'll order a couple o' Pro Micros and use the AVRdude instructions in The Guide.
Thanks for setting me on the right track!  :cheers:
« Reply #86 on: January 21, 2020, 07:56:57 am »
Finally got around to finishing the pinout images for Arduino Micro and Leonardo.   :embarassed:
Kill_one mentioned the Adafruit ItsyBitsy 32u4 5v 16MHz board here in JayBee's Lightgun thread.
- It looks like another great AVR option for the miniArcade 2.0 firmware.   ;D
https://www.adafruit.com/product/3677
https://www.amazon.com/Adafruit-ItsyBitsy-32u4-5V-16MHz/dp/B079SMYDRQ/
Zebra
  • Last login:February 22, 2020, 05:56:34 pm
« Reply #87 on: January 23, 2020, 09:11:29 am »
Does using an Arduino retain the ability to choose the output protocol to use it with consoles?
There are obviously tons of devices that allow the easy connection of analog, digital and optical controls but most only work on a PC. It would be great to have more options to use my real arcade controls on my PS3, Dreamcast, PS2 and Xbox.
It would be especially awesome if it was possible to output analog controls in PS3 Eye / PS Move format to use my positional guns on some of the ported shooting games that aren't well emulated anywhere else.
« Reply #88 on: January 23, 2020, 12:45:31 pm »
Pages 1-2 of the User Guide confirm that those four consoles are supported.
Output systems and connection:
- Dreamcast (custom RJ-45 cable)
- PS1/PS2 (custom RJ-45 cable) -- this also allows you to connect to 3DO, Famicom, Famicom (clone), MegaDrive / Master System, Turbo Grafx 16, Xbox 360, and other consoles using commercially available adapter cables
- PS3 (USB cable)
- Xbox (USB cable + female USB to joystick port adapter cable)
The miniArcade 2.0 firmware auto-detects which console the board is connected to and switches protocol automatically.
Check the pinout image for the AVR board(s) you are considering and the RJ-45 adapter cable pinouts on User Guide page 7 since some Arduino boards don't have connection points for all needed "RJ-45" pins/ports.
For example, the Pro Micro doesn't have a connection point for 32u4 pin 08 (port B0) that goes to RJ-45 adapter cable pin 5.
- This pin is needed for both the PS2 and DC adapter cables.
The Micro has connections for all of the "RJ-45" pins/ports, so it will support PS2 and DC.   ;D
The MattairTech MT-DB-U4 and Teensy 2.0 boards also have connections for all of the "RJ-45" pins/ports.
No idea if those formats are supported.   :dunno
That's a question for Bruno.
Zebra
« Reply #89 on: January 23, 2020, 02:16:37 pm »
The biggest question for me is if it allows you to output absolute controls instead of relative.
I can use my Titan One to connect my PC guns to a PS3 (via UHIDs or APACs) but when I try and play HOD4 I only get relative positioning which makes it impossible to aim.
If there was a way to get absolute positioning from analog sticks on games that only offered relative controls natively, it would open up cool possibilities. You'd be able to play Time Crisis 4 on the PS3 with real time crisis 4 arcade guns. You'd be able to play PS3 light gun and FPS games with a real light gun.
You'd also be able to use a TC4 or Sega arcade gun to play PS2 and Dreamcast light gun games on an HDTV with a gun that actually works properly.
It's probably possible via a custom script with my Titan One but that's way beyond my skills.
« Reply #90 on: January 23, 2020, 10:07:14 pm »
E-mailed your inquiry to Bruno.
His reply:
For "real arcade controls" on several consoles the best bet would be the RetroPad32 plus the USB Input Module (for USB based arcade controls) and the output cables for the target consoles.
As for PSMove/Gun support, we are out of luck with any of my projects though. :-(
Cheers,
Bruno
There's info about the RetroPad32 on Bruno's site here.
tus376h
  • Last login:January 28, 2020, 05:38:52 pm
« Reply #91 on: January 24, 2020, 03:42:21 pm »
His reply:
Cheers,
Bruno
Is Bruno able to provide RJ45 pinout details for his RetroPad32? I'm looking to use my MC Cthulhu RJ45 cables with the RetroPad32 but want to make sure I don't start shorting things out due to an incorrect pinout. Here's a thread I created asking the community:
http://forum.arcadecontrols.com/index.php/topic,161829.0.html
Thanks.
« Reply #92 on: January 24, 2020, 04:51:03 pm »
The miniArcade 2.0 RJ-45 adapter cable pinouts are on pages 6 and 7 of the User Guide.
- Connections on the console connector will be the same, but the RJ-45 connections may be in a different order.
I don't have any info regarding the RJ-45 adapter cable pinouts for miniConsole+ or RetroPad32.   :dunno
You mentioned in the other thread that you e-mailed Bruno yesterday.
Hopefully, he will agree to share those pinouts.   ;D
tus376h
« Reply #93 on: January 24, 2020, 10:33:44 pm »
Thank you for the input! I'm hoping for the same.  ;D
lilou
  • Last login:Yesterday at 04:55:22 pm
  • First arduino trial
« Reply #94 on: February 06, 2020, 04:55:03 pm »
Hello everybody,
i'm French and my english is not perfect, so sorry if i make mistake (i do my best).
In the past, i bought "KADE miniarcade" for my old arcade cabinet, and it was working perfectly.
Today i try to do the same thing with an arduino Pro micro.
So i read this topic, and all the PDF document.
After several trial, I have succeeded to write the arduino with avrdude. And it is recognized by the xbox like a gamepad PERFECT !
but no... because the buttons correspond to the basic software assignment not mine (exemple X is F5 but i asked X=D2)(other exmple : Left stick is on D3, but i don't assigned left stick on the mapper...).
I don't anderstand what go wrong
I put my own assignment on "kade miniarcade2.0 gamme mapper", i export to EEPROM.eep on the avrdude folder (i checked, the code inside eeprom file is different if i change assignment on mapper).
i execute the command "avrdude -p atmega32u4 -P COM12 -c avr109 -U flash:w:MINIARCADE2.hex ľU eeprom:w:EEPROM.eep -C avrdude.conf" and i have a confirmation "flashed verified"
but each time ... my assigment is not respected always the same assigment "by default" on arduino.
 Somebody can help me ?!?
 :dunno
« Reply #95 on: February 06, 2020, 11:07:48 pm »
1. Is there a reason you reassigned ports instead of using the defaults?
Seems easier to wire using the defaults than to change the ports.   :dunno
2. Since the buttons correspond to the defaults instead of your custom settings, you might be programming the board using the original EEPROM file.
If the EEPROM file is not loaded to the board, the HEX firmware reverts to the default joypad configuration.
After you exported the custom EEPROM, did you copy the new "EEPROM.eep" file from the "\firmwares\" folder to the avrdude folder? (User Guide, page 14, step 5)
3. When you reassigned ports, did you check that the same port wasn't assigned to more than one function? (User Guide, page 5, step 6)
4. Leaving an xBox function like Left Stick with the "Input As" port set to blank might cause problems for the firmware -- not sure if Bruno tested this possibility.   :dunno  (User Guide, page 5, step 6)
The defaults for Xbox have a port assigned to Button Mapping ID #s 0-5, 8-11, 13-17.
5. You may need to set Output Mode to "Force Xbox". (User Guide, page 4, step 4)
« Last Edit: February 06, 2020, 11:12:01 pm by PL1 »
lilou
« Reply #96 on: February 07, 2020, 06:36:56 am »
yes because arduino Pro micro do not have all buttons available. Only 12 output available, so i need to choose.
ok it's probably that
yes i did
yes i did, because i puted "blank" on unused buttons
ok... this is a serious possibility in my case
i tried that but nothing change.
lilou
« Reply #97 on: February 07, 2020, 07:03:16 am »
ok so, i try again.
I put the default setup, i juste flip A and B with Dpad up and down (no "blank" exept by default, and i check that the same port wasn't assigned to more than one function)
i flash the arduino and nothing change on xbox...
so do you see a mistake ? :
thank you
« Last Edit: February 07, 2020, 07:06:23 am by lilou »
« Reply #98 on: February 07, 2020, 10:00:43 am »
The command line looks correct.   ;D
The flash programming (MINIARCADE2.hex) messages look good, but there are no messages in the image you posted indicating that EEPROM programming (EEPROM.eep) was even attempted.   :banghead:
1. When you ran that command did you get any other messages that aren't in the image?
2. Is there a copy of your custom "EEPROM.eep" in the "avrdude" folder where you typed in the command line?
3. Is the filename exactly "EEPROM.eep"?
- IIRC avrdude filenames are case sensitive so "EEPROM.EEP" or "eeprom.eep" won't work.
4. Does the creation date match the date you exported your custom file?
- "dir /p" for a directory listing with prompt so list doesn't scroll off the screen before you can read it.
5. If 1 is no and 2-4 are yes, your Pro Micro's bootloader or fuse settings might be the problem.   :dunno
- I don't remember seeing another Pro Micro knockoff that uses COM12.
lilou
« Reply #99 on: February 07, 2020, 01:41:40 pm »
that's exactly what i noticed
nothing
yes for all
i don't know what it mean  :embarassed:
lilou
« Reply #100 on: February 07, 2020, 02:34:29 pm »
i solved my problem  :laugh2: it's realy stupid !
I was used a copy-paste of the code from the PDF tutorial
avrdude -p atmega32u4 -P COM12 -c avr109 -U flash:w:MINIARCADE2.hex -U
but the real code is :
avrdude -p atmega32u4 -P COM12 -c avr109 -U flash:w:MINIARCADE2.hex -U eeprom:w:EEPROM.eep -C avrdude.conf
one "ENTER" between and it dos not work correctly ! So, in only one line (not 2) the code works perfectly !
my eeprom is now upload !
 :cheers: :cheers: :cheers:
« Last Edit: February 07, 2020, 04:23:31 pm by lilou »
« Reply #101 on: February 07, 2020, 03:50:48 pm »
Glad you got it working.   ;D
lilou
« Reply #102 on: February 07, 2020, 04:23:14 pm »
Yes thank you, i am happy !
Do you know if is it possible to not use the RJ45 option, and add more button on the bord ? like the original "kade miniarcade" (and not miniconsole) ?
because with only 12 buttons is too short. I need 3 more  :lol
« Reply #103 on: February 07, 2020, 08:51:34 pm »
I don't know if the Xbox protocol will handle more functions/buttons than the ones Bruno marked in the "Output As" column of the Mapper program.   :dunno
- The only functions not assigned a port by default are Right Trigger, Left Trigger, the analog stick inputs, and some multi-button combos.
Yes, you can re-map the RJ-45 ports if you do not plan to use them to connect to a GameCube, Nintendo64, Wii, WiiU, or NES Classic console (User Guide, page 7) or to another console through a Multi-Out board. (User Guide, page 6)
Looks like these ports are available:
B1, B2, B3, D0, D1, D4, and F7
lilou
« Reply #104 on: February 08, 2020, 06:51:46 am »
you are the best !
I'm excited ! it's very super cool !
« Reply #105 on: February 08, 2020, 08:46:33 am »
Do the "combo" inputs (Button Mapping IDs 18-23) send a single button press to the Xbox or do those inputs send more than one button press to the Xbox?
For example, the Button Mapping ID 19 (port B2) "Output As" is labeled "Back + White".
Does grounding that input send one button press "Back + White" or does it send two button presses, one "Back" (Button Mapping ID 8 ) and one "White" (Button Mapping ID 4)?
lilou
« Reply #106 on: February 08, 2020, 02:17:09 pm »
I'm not sure to understand your request (I don't speak English perfectly), but if you use the option "output as back+start" for exemple, when you use only this button , the xbox will received information "back is press" AND " start is press
does that answer the question?
« Reply #107 on: February 08, 2020, 03:20:02 pm »
Yes.  Thank you for confirming that grounding one "combo" input causes the board to output 2-4 button presses.
Did you find a way to add the three more buttons?
If you did, which functions/Button Mapping ID numbers did you use for them?
lilou
« Reply #108 on: February 08, 2020, 06:25:06 pm »
i was searching how to use B1/B2/B3/D0/D1 ports who was not available on the "mapper" due to "Rj45" functions
So i found this option, and now i can use it like other one :)  :
So now, i have almost alls ports available on my arduino pro micro :)
(i just have to test "shift" function, I haven't tested yet)
« Last Edit: February 08, 2020, 06:28:11 pm by lilou »
« Reply #109 on: February 08, 2020, 08:46:01 pm »
I'm not asking how to enable the RJ-45 ports.   :banghead:
I'm asking which Button Mapping ID numbers you used for the three more buttons you said you needed.
Here are the Button Mapping ID numbers and the assigned functions for Xbox:
- 0-5, 8, and 9 are the usual Xbox buttons. (8 buttons)
- 13-16 are the D-pad, which acts like 4 buttons. (4 buttons)
- 32 and 33 are left/right trigger. (2 buttons?)
- 10 and 11 are left/right thumbstick button press? (2 buttons?)
- 24-31 are used for analog thumbstick inputs. (probably not usable as buttons)
- 6, 7, 12, and 34-46 have no function assigned. (probably not usable as buttons)
- 17-23 are "combos" of other buttons. (no new buttons here)
Seems like the place to find your three more buttons is 10, 11, 32, and/or 33, right?
lilou
« Reply #110 on: February 09, 2020, 04:34:33 am »
 :lol sorry,
first it was : ID 0-5 + 8-9 + 13-16 (=12 buttons)
i was needed in addition : ID 17+32+33
and finally i add : 17+32+33 and 18+10 (=17buttons)
« Reply #111 on: February 09, 2020, 09:58:10 am »
Thanks, lilou.   :cheers:
Hopefully this info will help the next person who wants to use a Pro Micro on their Xbox.   ;D
