A bit more progress over the past two days:
I have an old Samsung monitor with an adjustable base - the thing spins 180* and has an arm that lowers / raises the monitor and tilts. I was tempted to get rid of this thing long before I ever thought I'd be building an arcade, but I'm glad I hung onto it.
The bezel was silver, so I took it all apart and hit it with the rattle can. Because of the adjustability, I didn't have to mess around too much with finding the perfect angle. Instead, I just stacked a bunch of misc. items (chair, stool, books, kids foam blocks) and got the shelf to the right height. From there I marked the cab and installed the shelf.
I would have had it in last night but the wood strips kept splitting on me - go figure. This is the same lumber I used for my batons inside but I finally said screw it and picked up some small aluminum angle iron for the shelf supports.
Once in, I tested the monitor to make sure I didn't screw anything up and started loading my RPi etc. in the cab to start mapping out where things will go.
One thing I'm not clear on is how to wire up this lit power module to my power-bar. I got as far as cutting the plug off and crimping some spade terminals but have no idea how this thing works. Wiring is not my specialty... I looked on Google last night but didn't have much luck - if anyone has a shot of how this goes, I'd appreciate it.
Bezel removed:
Painted:
Reassembled:
One side in:
Second side:
Shelf installed - yeah, there's T-mold on it, you can laugh at me
. I had a chunk of black and figured 'why the hell not?'
Shelf drilled - Samsung was nice enough to put some threaded inserts in the bottom. Thanks Samsung -
Monitor works! Whew...
Powerbar leads crimped and heat-shrunk... no idea how this wires / where the jumpers go:
Lastly - artwork was all sent off and proofs came back today! It was pretty cool seeing everything in pre-production... can't wait to get the artwork on this baby.
