Main > Main Forum
Leaf Stick Comparison
Tailgunner:
As to fixing the actuator's length, a simple solution would be to add a washer or three between the actuator and the E-clip. For my quick test I simply used the Wico 4 way actuator instead. It made a definite difference in feel, but from just moving the assembled stick I could see the switches either need to be spaced out a little further or bent to adjust them. (Probably a bit of both.)
Lastly, to see how they work together I fitted all Wico parts to the repro base. Everything but the metal washer between the grommet and bottom plate would fit. The Wico grommet is a little taller, and the Wico's metal washer ended up being a bit too thick so I used the repro's metal washer instead.
Tailgunner:
Repro base, Wico balltop knob. If anything this combo would look better from the topside when there are Wico 8 ways on the same panel.
GroovyTuesdaY:
You didn't answer my question from above lol. Where did you buy them lol.
grrrrrroooooovy :D
Tailgunner:
--- Quote from: Tailgunner on January 25, 2004, 04:11:55 am ---Mine came from Centsible Amusements.
Did so. ;)
GroovyTuesdaY:
oh man, WHOOPS. i am sorry. Its late and my eyes burn lol
BAD GROOVY, BAAAAD GROOVY!! :-[ :-X
hehe.
Thanks man! :D
groovy~:D
