Arcade Collecting > Restorations & repair
Crossbow
<< < (2/3) > >>
Sparkolicious:
Applying the side art has been an issue. I had to throw a $60 sheet away because I didn't get it down correctly. Looking back, I should have applied contact cement to the entire side and then laid the sticker down. Lots of trouble the the adhesive not sticking. I've have to run a very low heat iron over some bad spots. A lot of work, but it looks pretty good. CP art was the same. I ended up using some contact cement to get it completely in place.
Sparkolicious:
I'm waiting on a replacement sheet of black vinyl from https://quarterarcade.com/ .  I'll some finished pic after I get er done.
CheffoJeffo:
Looks great.  :applaud:
At some point I have to should do the same to my Cheyenne/MultiExidy so am watching your progress. I had been thinking of priming/sealing the whole cab before applying new vinyl because I was worried about adhesion (and because a local guy I know always did that and his restos were pristine).
Are you planning to do any gun-related maintenance? Long ago I saw a blog post on Exidy gun maintenance, but haven't been able to find it since.
And I hear you about difficulties moving the beast. She is a might unwieldy.
Sparkolicious:
I would definitely seal the whole thing. The particle board just breaks down over time. I ended up with an entire side that I had to gently heat and work. So far is seems to be staying put, but I am sealing the other side.
When I bought this game it had been worked on. NOS monitor and boards are clean. My only issue is with the connection between boards. After a few minutes of play, the screen wigs out. If I move the boards a little it straightens out. I am assuming flaky connection between the two boards is the problem, but I haven't monitored voltages to see if the power supply could be the issue. The gun is in great shape except for two galvanized self taping screws used to screw the front of the crossbow on. You really would never noticed with it mounted, but I just can't put it back together without fixing it.
Sparkolicious:
DONE!!!! Finally! Control Panel overlay came out kind of like crap, but it is what it is for now.. I want to play! I ended up applying contact cement to the entire side to get the sides to stick well. I should have done the same for the CP. I have some areas on the CP that aren't sticking. I tried to apply light heat, but that made permanent creases. It doesn't stick out, but I know it is there, and it farks with my OCD terrible! Game plays though! Cleaned contacts between boards and played for a while with no video issues.
Navigation
Message Index
Next page
Previous page
Go to full version
