Author Topic: Installing Pinball Plunger for Virtual Pinball  (Read 11438 times)
dgrace
  • Last login:August 19, 2025, 01:24:41 am
« on: November 25, 2016, 11:08:52 am »
Does anyone know of any forums or youtube videos with detailed instructions on how to install and connect a plunger for Virtual Pinball (i.e. connecting the wiring, microswitch, etc.)? I have an IPAC4.  Does it connect to that?
I'm currently building a 4 player arcade cabinet which will have 2 side pinball buttons and a plunger for Virtual Pinball, Future Pinball and Pinball FX2 games.  Any guidance is much appreciated.  Thanks
thomas_surles
Re: Installing Pinball Plunger for Virtual Pinball
« Reply #1 on: November 25, 2016, 12:05:09 pm »
Do you want to use one of those expensive analog plungers or a real pinball plunger with micro switches?
dgrace
MTPPC
http://pinballmd.com/
fiatbravodriver
  • Last login:January 08, 2021, 09:22:44 am
« Reply #4 on: April 28, 2017, 12:50:05 pm »
Hi is it that easy the end of the rod hits the switch and done? my cabinet is almost done but have been wanted to add a plunger but they are soo expensive.
dgrace
« Reply #5 on: July 13, 2017, 02:43:03 am »
What are people's thoughts on the launchball button vs a plunger? Do you know where I could buy customized launch ball button or a smaller one? A lot of the launch ball buttons I saw were huge.
  • Last login:Today at 12:13:02 am
« Reply #6 on: July 13, 2017, 05:58:50 am »
Disclaimer: I haven't kept up with recent VP developments or new tables/scripts for a while.
It depends on
  1. The particular type of plunger (Microswitch? Analog? Mouse?)
  2. The particular table and plunger script
  3. Personal preferences and expectations
Some tables/scripts were designed to require precise timing of the shot -- advantage Ball Launch button.
Some require a precise amount of pull/force to make certain shots -- slight advantage mouse plunger (see sig) or analog plunger.
Some require a combination of force and timing which is extremely difficult if all you have is a Ball Launch button or microswitch plunger -- major advantage mouse/analog plunger.
You can get the best of both worlds by having both a launch button and a mouse/analog plunger.
Pick a button size/style you like.
If it doesn't have a clear/transucent cap get vinyl decals from Slammedniss.
If it has a clear/transucent cap print some custom inserts on Avery 8665/18665 (inkjet) or 15665 (laser) clear labels.
More info/links here.
