Main > Everything Else |
AM2R - Metroid is the bestoid! |
<< < (2/2) |
Le Chuck:
--- Quote from: pbj on August 22, 2016, 08:01:30 pm ---Freaking kotaku kills another one. At least I got Pokemon uranium in time.... --- End quote --- http://am2r.freeforums.org/viewtopic.php?f=2&t=1639 They never got the C&D so it's still available in their forums. Get it. |
wp34:
I finally got around to installing this for my mom today. She's loves the game but says she misses the music from the original. I didn't play it enough to know but maybe you guys recall. She's stuck on a section right now where it appears you have to speed run through some lava. Thanks again for hooking me up with this guys. :cheers: |
Howard_Casto:
I got stuck a couple of times and I just searched for a playthrough of the game and fast-forwarded until it showed the spot I was stuck on. Usually it was something dumb involving the map because the map, like those in other metroids of that era, can be misleading. |
Le Chuck:
In initial cave system (before you get into the more unique areas) there are multiple lava areas that block out large portions of the map. They open as you clear metroids so if you have any metroids on the counter in any of the areas then you're blocked access from the next portion. Have her clean the areas she has access to and then recheck the main cave system for new openings. Best I can tell you. |
wp34:
--- Quote from: Le Chuck on September 05, 2016, 10:21:53 am ---In initial cave system (before you get into the more unique areas) there are multiple lava areas that block out large portions of the map. They open as you clear metroids so if you have any metroids on the counter in any of the areas then you're blocked access from the next portion. Have her clean the areas she has access to and then recheck the main cave system for new openings. Best I can tell you. --- End quote --- That makes sense. Thanks. :cheers: |
Navigation |
Message Index |
Previous page |
