Main > Main Forum
Turbo Twist 2 Wiring Ribbon — What is the Order of Colors?
ghoolster:
No, mine looks like this at the other end.
holaplaneta:
--- Quote from: galla22k on July 02, 2016, 08:29:54 pm ---Awesome! Thank you very much. One last favor, does yours also have the gray ribbon cable like mine? If so, could you take one more pic where that splits back into colored wires? If it doesn't, no worries. Thanks again!
Did you figure it out? Could you share the Order of Colors? I am running into the same issue as you. I may get this cable and try: https://www.tinyosshop.com/index.php?route=product/product&product_id=643
RandyT:
--- Quote from: holaplaneta on May 28, 2023, 10:24:51 pm ---
Just a word of caution, if you get it wrong, it will very likely destroy the spinner. The colors on a random cable assembly are meaningless, so if you need this information, PM me or more preferably, contact me through the technical support address on the GGG website.
