Main > Lightguns
DemulShooter (Dual light gun on DEMUL, Model2, Dolphin, Silent Hill, etc...)
<< < (732/732)
dgrace:
--- Quote from: argonlefou on January 11, 2026, 03:33:36 am ---
--- Quote from: dgrace on January 01, 2026, 05:59:44 pm ---Hi Argon, I just tested v17.1 and for some reason my p1 Alien gun is not being recognized in the GUI (the device drag down). Only my p2 gun is recognized. Same with version 17.0. However, both my p1 and p2 alien mounted analog guns are being recognized in v16.4 GUI and before. So I assume there is some kind of bug in the latest version, or maybe i'm doing something wrong. Thanks in advance.
Update: It’s not a p1 vs p2 issue. It appears the GUI will only recognize one alien gun at a time. When both are plugged in, only one is recognized in the device drop down list.
Hi
Indeed, I was asked to make some changes on how guns ID are saved in the config file.
People tested a lot of guns to assure me  that it would have no impact.
But they didn't test with aliens gun and murphy's law did the rest.
See here : https://github.com/argonlefou/DemulShooter/issues/352
I think I'll need to rollback to the older way...
I'm aware of the issue, I just need to think a alittle before adressing it
v17.2 resolved the issue. Thanks Argon!
Headrush69:
Thank for all your work Argonlefou.
Just curious if there is any consideration of adding your custom outputs to mame now that it's Sega Model 2 emulation has improved so much?
I know MAMEdevs won't add outputs that aren't authentic.
argonlefou:
--- Quote from: Headrush69 on February 09, 2026, 09:07:24 pm ---Thank for all your work Argonlefou.
Ah, that's a good point !
I actually ported those Model2 outputs to be used with MAME when they first released 0.278 with Model2 game support.
But as it was not DemulShooter related, I shared it to some people for testing but never really advertised for it....
Just download and use the zip package I'm joining in below (there's a Readme inside explaining everything)
These are simple LUA scripts to be used with MAME to create outputs, DemulSHooter is not needed for that.
Headrush69:
--- Quote from: argonlefou on February 10, 2026, 11:17:11 am ---
Thanks for that.
I thought that using LUA might be a possibility, as you have the cheat system for finding memory location in MAME already with many cheats already pinpointing needed memory locations.
I was looking at the MAME documentation last night but wasn't sure about outputting the messages and I haven't used LUA yet.
Working great, thanks. Just need to dial in my recoil value.  :)
FANS:
Hello! It's been some months since I asked about how to use demulshooter with Wiimotes. I found a program called Lichtknarre which converts the inputs so it was recognized in Demulshooter. I can finally play some games in a proper way.
I have a question now, about the Chihiro games (Virtua Cop 3, House of The Dead 3 and Ghost Squad). I have played in old CXBX version with crosshair, but it seem the build Chihiro-DS has a better performance.
Using Demulshooter, it hides the crosshair. And using Wiimotes, it's hard to play without a crosshair, since it's not so precise. Is there a way to restore the crosshair in Chihiro-DS?
Navigation
[0] Message Index
[*] Previous page
Go to full version
