Main > Lightguns
DemulShooter (Dual light gun on DEMUL, Model2, Dolphin, Silent Hill, etc...)
argonlefou:
--- Quote from: midd on January 30, 2023, 10:33:11 am ---After seeing the latest videos, I'm trying to get HOTD3 setup to try it out with DS and Mamehooker but it won't run. Did the noCDcrack, run as an administrator. The game launches, screen turns white but then returns to the desktop. If anyone can help via PM, I'd appreciate it.
Hotd3 with or without the arcade mod ?
Can you run the game alone without anything else ?(Demulshooter, arcade mod, etc...)
vd2021:
--- Quote from: argonlefou on January 29, 2023, 07:18:01 pm ---Even if I do regret making things for Dolphin (way to complicated to debug, and I don't use it at all myself in the end)
Here are few steps that can help for diagnostic
1 - follow this : https://github.com/argonlefou/DemulShooter/wiki/Debugging
Do not use scripts, check admin rights and get a debug file, this may rule out any obvious thing
2- is Demulshooter hooking ? Does the icon stays red or become green ?
Next is the part related to dolphin config....we'll come to that later if needed
Please forgive my ignorance but, how do I "Add a -v option in DemulShooter command line (for example : DemulShooter.exe -target=ttx -rom=hmuseum -v)"?
I'm sure this is trivial for the majority here. I am trying to create a DemulShooter log file share here.
vd2021:
I attached the Debug from Demulshooter. I have the green "H" and Crosshairs in the systray. I hope I did this correctly. Thanks.
cack01:
Confirmed that 10.9.2 fixes the Crosshair issue in Rabbids. Works perfectly now. Thanks for making the update.
argonlefou:
--- Quote from: vd2021 on January 31, 2023, 11:40:05 pm ---
Thanks. Which version of Dolphin are you using ?
By the way, the green H icon is the one from Autohotkey. DemulShooter's icon is also suqared but with a black crosshair inside
DemulShooter v10.9.3
--- Quote ---- Disabled Cheats Window poping up in "Tomb Raider" when left+right mouse buttons are pressed (DemulShooterX64)
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
