Author Topic: model2 over rev and indy500 lan play  (Read 1757 times)
ant2
  • Last login:March 07, 2024, 08:30:50 am
« on: January 29, 2016, 05:35:14 pm »
Has anyone got these 2 games to work with lan play?
I saw a video on youtube for over rev,  but last i read it was unsupported.
SailorSat
  • Last login:Yesterday at 03:05:01 pm
    • For Amusement Only e.V.
Re: model2 over rev and indy500 lan play
« Reply #1 on: February 02, 2016, 05:51:40 am »
Depends... I used pretty much identical systems (hardware wise) for my emu setup - so they "should" be equal in performance.
Most of the "later" games a better network check, and the m2em miserably fails it ;)
We got ManxTT to link up and sucessfully played some rounds of Motoraid (which is actually pretty fun).
Indy500 links up with a maximum of 3 players (more than 3 will cause the network check to fail), but one has to be considered very lucky If you can finish a race without "NETWORK ERROR".
As for OverRev - I think the Jaleco games used different comm boards or at least different roms. The MAME source even has a unique handler for jaleco comm boards, as the games wouldn't even start up with the comm board missing.
Only idea I have for Indy500: try setting/adding "FrameSync=1" in m2network.ini to improve the sync
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
MrThunderwing
  • Last login:March 21, 2024, 05:57:23 pm
  • As I pass, do I give you the ass or the crotch?
« Reply #2 on: February 03, 2016, 04:02:49 pm »
I've been able to get a single system 2 player networked version of Indy 500 running, but if I try a proper 2 PC LAN I always get the network error message. Likewise, I've never got OverRev working in any linkable form whatsoever. No problems LAN-wise with Manx TT or Motoraid though.
