Main > Raspberry Pi & Dev Board
Auto switching Nanao MS2930 with Arduino.
DebGugel:
Can you please share some more details here?
I want to know about the specifications of the all hardware components you are using.
Also share the schematic if you can share please.
seo expert
chrisvg:
--- Quote from: DebGugel on January 18, 2016, 01:02:51 pm ---I want to know about the specifications of the all hardware components you are using.
Hi Deb,
If you click the 123d.circuits.io link in my original message you will see a breadboard circuit layout with components.
The components I used are: Arduino Uno, 2x 10k Resistor, 1x 2.2k Resistor, 1x 56k Resistor, 2x N-Channel MOSFET 60V 30A.
Hope this helps!
burn_654:
You mention Radiant Silvergun - is this the arcade version running on Mame or a Saturn emulator like SSF? If it's the latter I never had luck running the game in native res. on a 15khz display...though the details escape me as it's been a while. I just remember going with the Saturn emu and dealing with it being in interlaced mode. Which emu is supporting the resolutions changing?
chrisvg:
--- Quote from: burn_654 on April 08, 2016, 04:47:33 pm ---You mention Radiant Silvergun - is this the arcade version running on Mame or a Saturn emulator like SSF? If it's the latter I never had luck running the game in native res. on a 15khz display...though the details escape me as it's been a while. I just remember going with the Saturn emu and dealing with it being in interlaced mode. Which emu is supporting the resolutions changing?
Playing it using GroovyMAME, it automatically switches modes between the game itself (low res) and the title screen (high res). I've only tried it on my tri-sync monitor and never experienced any issues.
burn_654:
Good to know, thank you!
Navigation
[0] Message Index
[*] Previous page
Go to full version
