Front End Support > Maximus Arcade
MA cut off screen
Yenome:
well depending on how its setup in windows i think the two monitor setup might be whats causing your issues with MA being off center. i have been unable to recreate your issue. even with the monitors set diff i still have no issue like your self. it almost doesnt sound like an issue with MA but with the setup and how its handling the two monitors. I would say unplug the second screen start MA and see if it goes to normal if it still is off center then we know it maybe with MA
Hiren:
Yep, that did it. Maximus does not like my dual monitor set up. thanks for the help.
Yenome:
in order to get the same issue i had to make two monitors work as one in an eyefinity display instead of extended desktop. so you might be able to play with how they setup to get it to work. what video card you using?
Hiren:
a single gtx 690
Yenome:
I dont think it would be but it could be defaulting to use the two monitors as one big screen.
Navigation
[0] Message Index
[*] Previous page
Go to full version
