Author Topic: Another first timer post  (Read 15618 times)
fryed_1
  • Last login:June 22, 2017, 11:15:35 pm
« on: November 13, 2015, 12:39:51 pm »
Been playing this for more than a decade now without actually building a cabinet.  It's gone from laptops to mini-pcs to raspberri pi and everything in between over the years.  Couple different pre-fab controllers (xarcade and such), monitors, crt, lcd, etc... and finally, now that I have a house with a big enough garage/mancave, have started on my cabinet.
Use basic dimensions found here on other projects and modified them to suit my tastes and it's almost alive!  Just ordered controls to build a CP - going 2x JLW 8-ways, HAPP buttons, 6 per player, 2 player buttons and 3 admin and 2 coin buttons.  Also went with trackball.  I'll add a spinner later, maybe a flight stick.  Trying to figure out a way to have a detachable CP so I can swap them out with a single USB plug for each so I can eventually incorporate steering wheel/shifter in to one, flight-stick/spinner/trackball in another and whatever else... maybe light guns?
Simple 12v mixer allows for 2 inputs.  Will have a 4x75watt car audio amp with all-range speakers above the monitor and an 8" sub built in to the bottom of the box below.  Will be putting an ipod dock in it as well with 3x volume (master, game, ipod).
24" dell LCD monitor, bezel will hide the front panel controls with graphics on it, plexi over the top.  Of course will be getting the full laminate and tmolding treatment with graphics after I let it sit for a month or so as is to make sure I like how it stands and plays.  Rough draft of my monitor mount made from stripping the old monitor stand of parts, so if something goes wrong with it, you push a button on the back of the monitor, remove the plexi and it pops right out the front.  Monitor mount will get beefed up a little as well now that I have the sizing down right for the mounting blocks.
CPU is a laptop I had sitting around.  i7 3630QM, 16gb ram and nvidia quaddro k2000 I think?  Yeah overkill I know, but I had like 5 of these sitting around collecting dust and figured it would take just about anything I throw at it.  Xubuntu base install, emulation station and compiling mame and other emulators to get rid of nag screens and such.
Built the frame last weekend to make sure everything fits together like I wanted.  This weekend will be pulling it apart, evening up the lines and adding 2x4 internal bracing and putting it all back together in it's final pre-finish form.
fryed_1
Re: Another first timer post
« Reply #1 on: November 17, 2015, 10:03:42 am »
Added some 2x2 and 2x4 internal bracing to stiffen it up.  Built a vented laptop shelf.  I have some of those wiring strips used in home theater installs left over from doing the house setup to route all the wires through on the side of the cab to make it look good on the inside I'll install later.  Measured and lined up the monitor shelf to take the plexi.  Controls on order from ultimark just got the DHL shipping notification today so hopefully they'll be here end of the week maybe.  Also wired up the LED strips for the marquee lighting.
Over the next few nights will likely start on filling in some of the inconsistencies (never really done much woodworking before so most of this is trial and error learning), sanding down smooth and routing for t-molding.
For mounting the plexi and marquee, not sure what they're called specifically, but I've seen them on other projects here as little "trays" that the plexi sits in - I used some similar stuff, but larger, to cap off the small 1" tile backsplash I did in the kitchen a while back.  Anyways that will be on the bottom and on the marquee something similar, but in L-shape I found on the top that will have a couple thumb screws holding it on.  For the display plexi, will use the same stuff on the bottom and there's just enough of a gap in the top where I will put felt strips down the front of the monitor-side bezel (to give a little room to avoid pushing buttons) where when you install, it will slide up in to the cabinet, press flat against the monitor and then slide down in to the "tray".  Gravity and pressure from the monitor slightly pushing out and the tray/sound board up top pushing in will hold it in there tight enough that I shouldn't need to drill screw holes or anything to keep it still.  If there is an issue with it sliding, I measured the plexi so that I could install clips on the inside top of the sound board above the display plexi (on inside) that I could reach from the access panel in the back to hold it in.
fryed_1
« Reply #2 on: November 19, 2015, 02:58:42 pm »
Little more work done today.  Bottom subwoofer and power supply section built.  Above it will be a storage cab.  The bottom will be hinged and allow access to the sub/PS area if needed.  I'm toying with the idea of barn doors with magnetic push latches to hold them closed.  Not sure yet.  The third empty spot above the storage cabinet I'll build a shelf to hold the amp and other wiring below the laptop shelf.  I was able to short out the laptop lid switch to thinking it was always open.  That prevents it from going hibernate or turned off with it closed all the time (similar to how a docking station fakes it)... For power on, BIOS has a setting on what to do when power is detected and the lid is open, so that's simple.  I take the battery out and leave it out.  Once I put the power switch in, you turn it on, laptop detects power and turns on and boots.  Power off might be an admin combo-macro or whatever button with a custom end screen "It is safe to turn the power off now..." so you can then flip the switch on the back.
Started mocking up the control panel and drawing out button layouts and all that.  Won't really touch it until they get here from UK, so maybe after the weekend will work on getting it up and playable with controls.  So here's how it sits until the CP gets here.
And until then, a new project has arrived I need to get setup and rolling this weekend....
tomstewdevine
    • A Comic Book Look
« Reply #3 on: November 19, 2015, 03:14:13 pm »
It's coming together nice work. I'm interested in how your Control Panel is going to work out, it doesn't look like it will be recessed at all into the cab.  Is it going to be flush with the sides?
fryed_1
« Reply #4 on: November 19, 2015, 03:14:39 pm »
FWIW advice/ideas are definitely welcome.  This is my first cabinet, though I'm no stranger to emulators and my first "real" woodworking project, so I'm taking my time, soaking in the info and going from there.  For example I know I might have some issues with the buttons clearing under the CP and not sure if I want to "elevate" it a few inches with some kind of structure underneath or route out on the 2x2 where buttons would go.  Maybe even route out some more 3/4" MDF, sandwich it to the CP top and hide all the wiring so it's smooth underneath and give it a little more clearance or something.
I'm not as concerned about authenticity, hence LCD monitor and all that, but more just having fun.  Since monitor has HDMI, VGA, DVI, DP and composite (5 selectable inputs), I'm considering putting a slot for a cable box in the back so I can use it as a garage football tv/arcade/jukebox/movies/etc... all-in-one machine.  The storage below I'm building in to it because I'd like to find a way to make a detachable control panel with a single USB plug so I can easily swap to one with trackball/spinner/flightstick without having everything crammed in one.
« Reply #5 on: November 19, 2015, 03:20:41 pm »
Lose the 2x2's, at least where the buttons will be.
Have the CP top overhang the edges a little bit like Martijn's Street Fighter:
...and trim it out with t-molding
http://forum.arcadecontrols.com/index.php/topic,84649.0.html
fryed_1
« Reply #6 on: November 19, 2015, 03:32:06 pm »
Well I've got this stuff leftover from a backsplash install in the kitchen which should work great to seat the plexi at the bottom of the monitor.  Still brainstorming for the top though.
CP with another 3/4" MDF on the bottom which should give plenty of button room underneath both hides the rail above and gives room on it to hinge from the back.  Perhaps some quick release hinges like Jeep doors and a spring-loaded latch on the front bottom with the trigger accessible from the bottom front of the CP would work - add a couple 1x2 braces that will disallow side to side movement and make it more stable.
Speak of the devil... as I'm replying, DHL shows up at the door.  Gotta praise Ultimark for being quick half-way around the world from me!
fryed_1
« Reply #7 on: November 19, 2015, 03:43:40 pm »
I am going to cut some of them out in the middle.  Wanted a stronger point to possible hinge the CP on the back side than just MDF.  Once I get the CP cut out, I'll trim out the middle of the 2x2 to fit the buttons when it's closed.
fryed_1
« Reply #8 on: November 19, 2015, 06:17:01 pm »
CP measured out.  Will grab new bits and a router on the way home from work tomorrow.  Going single sheet of MDF, 1" lip over the sides and front that will get tmolding and will have to route out some of the middle of the 2x2's, but would really like to keep them there to support hinges if I decide to add them.
Frank Drebin
  • Last login:January 11, 2022, 04:27:19 pm
« Reply #9 on: November 19, 2015, 08:12:34 pm »
Is that MDF or particle?
fryed_1
« Reply #10 on: November 20, 2015, 09:18:13 am »
Sorry it is particle.
« Reply #11 on: November 20, 2015, 09:49:19 am »
Lots of commercial cabs back in the day were made with particle, and since you are laminating you should be alright, but you definitely want to raise it up off the ground with some casters or feet (Twisted Quarter sells them), as particle is super susceptible to water damage.
Also I still don't get what you're doing with the CP, the first pic makes it look like its not flush with the sides, but then your next pics make it seem like there will be some overhang?
I know that I'm a CRT lover, but I'm glad you got an LCD that fits the scale of your cab... Noting worse than a skinny screen that barley takes up enough real estate, it looks really good so far.
Also... Don't but a spinner or flight stick on it, save those for your next project!  :cheers:
tomstewdevine
    • A Comic Book Look
« Reply #12 on: November 20, 2015, 10:15:31 am »
What are you going to use for your select button? I get the CP now, and it should work fine even with those 2x2's.
fryed_1
« Reply #13 on: November 20, 2015, 10:17:18 am »
Yes I have some heavy duty casters like the ones on the Kobolt workbench behind it in a few of the pics.  Just haven't laid it down to put them on yet, easier to work on it while it's on a dry floor and a little more immovable.
I'm only about 75% sure what I'm doing with the CP at this point as well hehe.  Building as I go... will build the panel as it is now, tack it on and get it playable for a week or so, then decide whether to make it perm or rebuild.
fryed_1
« Reply #14 on: November 20, 2015, 10:22:40 am »
3 not enough?  So far with keyboard, I can do everything for MAME I need with those three that doesn't require any admin/menu functions... so use the joystick to navigate between games, play to start it up, pause to pause it and escape brings you back to the emulationstation screen.
I have 9 generic white buttons that I can use.  Not sure if I'm going to do the pinball buttons on the side or not yet, but 3 are on the CP right now.  Was planning on 2 others out of the way but accessible to assign macros to flip between game/jukebox mode and need to figure out a place for a coin drop button.
I considered putting some consoles on it but will probably not.  Console games are more longer playing and I couldn't see doing something like all of Super Mario series or Zelda standing up at a machine like this.
« Reply #15 on: November 20, 2015, 10:44:32 am »
No need for a dedicated select button.
I've found most of my guests instinctively press the first button on player 1's side since they are already using that joystick to navigate.
I originally had the player 1 start button mapped to start games, but it was always the second button they tried.
IMO all you really need is a dedicated exit button.  Pause is nice to have, but not 100% necessary.
tomstewdevine
    • A Comic Book Look
« Reply #16 on: November 20, 2015, 11:49:48 am »
I'm a ---smurfing--- idiot, I didn't see that the one button said play. Carry on....
fryed_1
« Reply #17 on: November 20, 2015, 07:15:12 pm »
Getting closer. Not sure I'm liking the CP layout yet. Definitely rebuilding it using stronger wood because I don't really trust the strength of particle board if you're going to be slapping the joysticks around. Will get it wired though and playable tonight and see how it does.
tomstewdevine
    • A Comic Book Look
« Reply #18 on: November 20, 2015, 08:16:52 pm »
If that particle board is 3/4 inch you are just fine, it will be plenty strong for a CP.
mgb
  • North East, US
« Reply #19 on: November 20, 2015, 10:20:30 pm »
Control panel layout looks decent but possibly a bit much space between buttons.
Progress is looking good though
Control panel may also look a little better with a slightly rounded shape to it.
fryed_1
« Reply #20 on: November 20, 2015, 10:23:48 pm »
Yeah I have P1 wired up and I'm not extremely comfortable with it. Coin button in the center until I get a hole saw to try out the trackball.
Other than that I doubt I'll get around to wiring up P2 tonight because I'll like be playing all night!
mgb
  • North East, US
« Reply #21 on: November 20, 2015, 10:29:51 pm »
It's miller time.
you need to get plenty of test driving in before making these decisions.
Yenome
  • Last login:November 14, 2025, 04:36:28 am
  • Punch a fish. Make a wish
« Reply #22 on: November 21, 2015, 01:36:45 am »
is it just me or does the row spacing on the buttons look overly large. it might just be camera angle but it looks like there is too much room between the two rows. particle board is find i build an arcade stick out of 3/4" and it has held up nicely.
mgb
  • North East, US
« Reply #23 on: November 21, 2015, 01:46:45 am »
yes I also mentioned the large spacing.
it'd be best to have the butons near touching
EMDB
  • Project RetroCade
« Reply #24 on: November 21, 2015, 02:21:19 am »
I agree. Use the templates from slagcoin. Also the sticks seem to be undermounted without recess. The shafts are too small now.
mgb
  • North East, US
« Reply #25 on: November 21, 2015, 09:13:57 am »
They look good to me
fryed_1
« Reply #26 on: November 21, 2015, 09:48:29 am »
I routed out about 1/4" of the 3/4" total.  I thought they looked rather short from what I remembered as well, but it does feel pretty natural playing.
« Reply #27 on: November 21, 2015, 07:37:20 pm »
On the buttons:  I usually mount them so the nuts on the back are just touching.  It gets them as close together as possible and keeps the spacing uniform even if my mounting holes aren't.  Having a button wrench makes life easier when the buttons are that close together.
fryed_1
« Reply #28 on: November 21, 2015, 08:41:41 pm »
8way sticks are very finicky on 4way games like pacman.
mgb
  • North East, US
« Reply #29 on: November 21, 2015, 09:53:15 pm »
If by "finicky", you mean "suck", yes you're correct
vwalbridge
« Reply #30 on: November 21, 2015, 10:21:54 pm »
+1. And that was funny.  :lol
« Reply #31 on: November 22, 2015, 12:35:10 am »
If 4 way games are important to you consider making the next project a classics cab.  There is no need to make a cab that HAS to play everything.
Also please consider uploading your pics to the forum and sizing them a bit smaller.  It's harder to follow your progress when we can only see your pics on some platforms and phones can't scroll easily with large pics.
fryed_1
« Reply #32 on: November 24, 2015, 10:30:18 am »
Well I tried out the JLW in 4-way mode by rotating the restrictor plate on the bottom and worked much better.
Reading up, they will take servos so you can rotate them manually I think.  I don't suppose Mame will detect automatically if it's a 4/8 way game and rotate it for you would it?  They also have hardware mode where I could add a simple 4/8 way toggle.  Anyone thing that would get confusing for players that aren't tech savvy to realize what that means?
« Reply #33 on: November 24, 2015, 10:41:04 am »
As I recall there is a plugin for Mala that DaOldMan wrote to do what you're thinking, but Mala development is dead so I'm not recommending it as a front end any longer.
Personally I'd design it so that you can just pop the panel and turn the restrictor, but if that's not clean enough for you there are top mount solutions.
Or you know... just build a separte cab for 4-way games...  ;)
« Reply #34 on: November 24, 2015, 10:53:00 am »
I believe LED Blinky can trigger the joystick switching.
EDIT: http://www.ledblinky.net/ledblinky.htm  yup, listed in the features
I'm using Mala, but...what harveybirdman said.
« Last Edit: November 24, 2015, 10:54:38 am by BadMouth »
fryed_1
« Reply #35 on: November 24, 2015, 11:03:45 am »
I'd love to, but between tools, 13 bikes and her wanting to park her van in the garage during the colder months, room for a second cab is very limited.  The JLW stick has a geared restrictor plate on the back and I see they make servo kits for the other JLW based sticks on Ultimarc... I'm thinking it wouldn't be too hard to use the LED program listed below (I had looked at it for lighting up the buttons that a game used as it started) to activate the servo and move to/from 4/8 way mode when you start the game.  However it's windows only... maybe take another look at hyperspin over emulationstation on linux.
Alternatively, a simple 2-way toggle in the CP to select 4/8 way would work as well, but I'd like to automate it as much as possible.
« Last Edit: November 24, 2015, 11:05:49 am by fryed_1 »
« Reply #36 on: November 24, 2015, 11:23:57 am »
This might be helpful reading
http://forum.arcadecontrols.com/index.php?topic=116602.0
He used Randy's version of the JLW, the Omni 2 and Mala, and he's a legend (even if he has posted only once since September, we miss you if you're reading this bruh)
fryed_1
« Reply #37 on: November 24, 2015, 11:53:36 am »
That's good info harveybirdman, thanks!
fryed_1
« Reply #38 on: November 25, 2015, 11:18:51 pm »
Off topic but after a few days of pouring concrete, rebuilding decks and having friends over to test drive the new arcade, topped it off by christening this tonight.
Got some bugs to work out on the machine. Plays well, but there's some bottom combos that are activating OS features like alt-tab and such and interrupting the games.  Overall they were impressed and a better CP layout will make it much more comfy.
« Reply #39 on: November 26, 2015, 07:09:39 am »
Not sure what interface you are using, but it's best to ditch the first four default mame keys at the encoder level if you plan to run emulators other than mame.  The ipac can be reprogrammed.  On the key wiz, I just use different inputs and then use things like ALT for admin or coin buttons that won't be hit during play.  There are software workarounds, but it's easier to just start out with keys that don't cause problems. It only takes a minute to remap those four keys globally in mame.
I you only plan to run mame, then just disable hotkeys in windows. (Google it)
