Author Topic: How to setup a wheel in nullDC?  (Read 2521 times)
xela
  • Last login:March 09, 2016, 01:13:49 am
« on: October 28, 2015, 07:43:02 am »
Hello,
Can someone please explain how to setup a wheel (I have the Thrusmaster T500RS) in nullDC?
works perfect the Sega model 2 and 3 but in the nullDC it looks like the pedals are pressed all the time.
thank you.
  • Moderator
  • Last login:Yesterday at 06:49:25 am
Re: How to setup a wheel in nullDC?
« Reply #1 on: October 28, 2015, 09:08:01 am »
From the stickied driving cab info thread:
       nullDC 1.0.4 r50 w/PuruPuru plugin(included) - Dreamcast (Hydro Thunder, SF Rush 2049)
                                                    Configuring the controls can be difficult due to the pedals registering while
                                                     you are trying to program the other buttons.  Combine the pedals and
                                                     decrease the sensitivity during configuration, then change it back when
                                                     you are done. Gas=Rshoulder, Brake=Lshoulder on most games.
xela
« Reply #2 on: October 28, 2015, 03:38:18 pm »
Thank you, but I already read it and followed the instructions before posting the question, but I still have a problem.
It looks like the gas is pressed permanently and I can't change it.
The middle pedal acts like reverse and not like a break.
  • Moderator
« Reply #3 on: October 28, 2015, 03:51:35 pm »
In some games when the brake is fully depressed, the car goes in reverse.
Sounds like the pedal is inverted.
You said "middle pedal", so I assume that means you also have a clutch pedal.
Try to keep the clutch pedal exactly halfway depressed when mapping the other controls.
Turning the sensitivity way down or off should help.
