Author Topic: Burger Time To-Go: Portable Bartop  (Read 4885 times)
randjamal
  • Last login:March 18, 2026, 08:12:17 pm
« on: September 30, 2015, 10:06:31 am »
After completing two bigger projects (standup and a conventional bartop) I wanted to take the lessons learned and do a simple potable bartop.
I had three goals for the project:
•   Lightweight
•   Simple
•   Cheap! – total cost came in around $75
Specs:
•   Ό” MDF
•   Old atom netbook
•   GGG Leaf pro 4way joystick
•   GGG classix buttons with leaf switches
•   Zero delay encoder
•   Mala FE
•   Limited game list (1 button 4way vertical classics)
Thanks to shrunkenmaster who provided his art files and mala layout from his amazing BT build
In the end it isn’t a work of art, but I’m fairly happy with how it turned out. Please let me know if you have any questions/comments/criticisms.
Re: Burger Time To-Go: Portable Bartop
« Reply #1 on: September 30, 2015, 10:16:06 am »
Good work!
1/4" is tough to work with, is it mostly glued?
randjamal
« Reply #2 on: September 30, 2015, 10:30:18 am »
Good work!
I glued 1/4" square dowels down as battens, then glued to those. The back panel and top panels are screwed into 1/2" square dowel battens which are glued.
I should have done threaded inserts in the back for access, but they're screwed directly into the blocks. I'm hoping they'll hold up. I've tried to limit the number of times I screwed/unscrewed the back panel.
Slippyblade
« Reply #3 on: March 12, 2016, 08:19:02 pm »
Just noticed this build.  Looks great!  Did you dismantle the netbook and flip the screen around?
randjamal
« Reply #4 on: March 14, 2016, 09:12:40 am »
I did. That was actually the first step. The dimensions of the rest of the build were based off the dimensions of the netbook so I could make it as small as I could without going too crazy.
Slippyblade
« Reply #5 on: March 14, 2016, 01:57:19 pm »
I totally love Burgertime.  Absolutely suck at it, but enjoy it.  Also just followed the link to ShrunkenMaster's BT build, very cool as well.
vwalbridge
« Reply #6 on: March 14, 2016, 02:24:49 pm »
Yes Burgertime is such a great game. But I too suck at it. There is some really clever strategy to playing it well. However, I don't think I've ever passed the 4th stage. :laugh:
