Author Topic: How can I shift the the game image in MAME per game?  (Read 4012 times)
Wags
  • Last login:September 15, 2021, 08:46:48 pm
« on: September 02, 2015, 05:23:53 pm »
I have a two player control panel, with a trackball and spinner in the middle, and when playing one player games I am off to the side a ways and for the vertical games like Galaga, I would like to shift the game to the left side of the screen so it is more in front of me.  Is their a way to do that with the MAME software?  I am using MALA front end, and I don't see an option there either.
For games like PacMan that don't use buttons, I use the player two joystick, and play with my right hand, so I am centered.  But games like Galaga, I use the player one joystick, and am not happy with the game not being in front of the joystick.
I did search, but maybe I used the wrong terms, any help would be appreciated.
Thanks,
Mark
vwalbridge
Re: How can I shift the the game image in MAME per game?
« Reply #1 on: September 02, 2015, 05:29:47 pm »
If you are familiar with Retroarch, you can achieve what you are looking for. You can position the game screen anywhere on the screen.
Here is a quick setup guide:
Wags
« Reply #2 on: September 02, 2015, 05:40:27 pm »
Thanks, I'll have to check it out.  I am amazed how many pieces of software I am loading to get this cabinet to work the way I want.
vwalbridge
« Reply #3 on: September 02, 2015, 05:45:59 pm »
Check out my coleco video here:
Fast forward to about 10:50 of the video and you will see where I show you how I slid the super mario bros game screen down to the bottom. A little better for a horizontal game on a vertical screen.
Not exactly what you are trying to do but the concept is exactly the same. Retroarch is very flexible with screen ratios and placement.
« Last Edit: September 02, 2015, 05:48:28 pm by vwalbridge »
Wags
« Reply #4 on: September 03, 2015, 01:36:21 am »
Cool, I am assuming that it will work fine using a low resolution CRT display connected through S-Video.  Correct?
matsadona
« Reply #5 on: September 03, 2015, 02:33:26 am »
Based on your question about having the display output off center I assume that it is a horizontal screen. I'm not sure playing a vertical game on a horizontal low res screen will be a good experience (because of the pixel scaling etc). If it was a HD monitor it is more feasible...
DarthMarino
  • Last login:December 17, 2025, 10:53:45 am
« Reply #6 on: September 04, 2015, 09:30:39 am »
Another option is to make a simple .lay file.
Wags
« Reply #7 on: September 04, 2015, 09:50:27 am »
And how does that simply work?
As far as the horizontal monitor with vertical games goes, there are a crap load of people doing just that with great results, and by low resolution, I mean a 480i TV, which gives well over the 224 x 288 that games like Pac-Man use.   :P
matsadona
« Reply #8 on: September 04, 2015, 10:44:03 am »
Ah, great. Thanks for the clarification.
Do you have any flickering issues with that setup? What's the hardware?
« Last Edit: September 04, 2015, 10:46:57 am by matsadona »
DarthMarino
« Reply #9 on: September 04, 2015, 08:25:38 pm »
Something like this (adjust the values that best work for your screen):
<mamelayout version="2">
   <view name="Image Shift">
      <screen index="0">
         <bounds x="0" y="0" width="1024" height="768" />
      </screen>
</view>
</mamelayout>
Then just use the sliders in MAME to get the stretch and position to your liking.
