Main > Monitor/Video Forum
Golden Tee 2005 Video Help!!
tommytrish:
I switched 1 to Off and it fire up correctly. I switched 2 to off and got jumbled picture. Still missing the left 1" of the screen
bsoder52:
Hi guys!
Came across this thread while trying to get my 2005 GT Complete PCB board connected properly to a Dell 20" Computer Monitor via an 8200 V4 VGA Converter board. I've tried all the various clamp settings and resolution settings without much luck. My problem is I'm getting a shakey screen picture. I can't even read the on screen dip switch settings. I've scoured the interwebs looking for answers and this is the first post I found talking about physical dip switches on the board, which I didnt even know were there until i searched for them. they are tiny. I've tried adjust them without much luck yet. Any advice to would be much appreciated!
Thanks for any help.
bsoder52:
The monitor is a Dell 2007FPB, 4:3 1600X1200 in case that makes a difference on any suggestions thanks!
lilshawn:
AGAIN as mentioned before here, http://forum.arcadecontrols.com/index.php/topic,129561.msg1325609/topicseen.html#msg1325609
bsoder52:
Ok, so because of this:
golden tee outputs something OTHER than standard resolutions.
resolution: 640x350
h-frequency: 25.7KHz
v-frequency: 60.6hz
pixel clock: 21.5khz
it's the 25.7khz that's the kicker.
the cga/ega frequencies the converter can handle are
14.5 - 16.5khz -which is cga
23.5 - 25.5khz -which is ega
30.5 - 32.5khz -which is vga
as you can see, the frequency falls just outside into the space between ega and vga
Neither the medium or low resolutions settings on the GT board will work correctly transitioned to the monitor via the VBA converter?
Am I understanding that correctly?
Should I just get a different monitor?
Thanks for clarifying, Im not the most technical guy.
