Main > Raspberry Pi & Dev Board
Sound issue in MAME
jboddez:
Oh, are you using HDMI or the analog video out? (Sound may also be transferred over HDMI, so it could be of importance.)
uhoh:
--- Quote from: Aceisback on June 14, 2015, 10:56:13 pm ---Just a thought, I found this, but not sure if it is what you are dealing with:
http://piplay.org/forum/discussion/968/usb-audio-card-issue-with-piplay-/p1
Thanks for linking this, solved my issues with usb sound working everywhere but MAME.
Sound is much better using usb on my Pi2- analog had a constant hiss.
Aceisback:
That's weird that mame does not have any sound. Did you go into the mame settings (TAB key) and check the audio settings there? I know you can adjust the volume there if I remember correctly. I know I had to adjust the volume on my setup.
Peabo:
Are you getting static in the sound? If so, you need to use an AV cable and not a stereo cable like this one: http://www.amazon.com/gp/product/B00W8FHIYQ?psc=1&redirect=true&ref_=oh_aui_search_detailpage The headphone port is actually an AV port, so with a stereo cable the top ring isn't separated and the video and ground are connected causing static in the audio.
uhoh:
--- Quote from: Peabo on July 23, 2015, 09:51:39 pm ---Are you getting static in the sound? If so, you need to use an AV cable and not a stereo cable like this one: http://www.amazon.com/gp/product/B00W8FHIYQ?psc=1&redirect=true&ref_=oh_aui_search_detailpage The headphone port is actually an AV port, so with a stereo cable the top ring isn't separated and the video and ground are connected causing static in the audio.
I actually have one of these kicking around somewhere and will try this before mucking with usb again on a fresh 3.0 RC1 install. Thanks for the tip!
Navigation
[0] Message Index
[*] Previous page
Go to full version
