Arcade Collecting > Pinball
Backglass size?
jackiabu:
--- Quote from: kixfan on May 03, 2015, 07:10:05 pm ---I have a 39" PF 23" BG and use a 15" for DMD. In a standard mid 70's Bally cab (FYI - that I salvaged from a barn that was stripped and rotting). Anyhow, a 23" fits almost perfectly width wise. I will also throw out my 2 cents for virtual pins, They can be fun to play and help you learn certain modes but if you plan to compete in league play, it could cause your timing/gameplay to be off. While VP10 should help in realism and physics it's just not the same.
Thanks men :)
i dont think i will instal VP too much headache :dizzy: i already install Futre pinball and hyperpin for the fronted.
insx:
Neither looks quite right but if it is a 2 screen setup, I prefer 4:3 (or 5:4).
Connorsdad:
I highly recommend adding vp to your build along with all the toys for feedback, so much better :)
jackiabu:
this topic has been moved to here : http://forum.arcadecontrols.com/index.php/topic,145542.0.html ;)
AGK64:
Impressive project! Best of luck to you! :)
Navigation
[0] Message Index
[*] Previous page
Go to full version
