Author Topic: Mame console.  (Read 21041 times)
Rock
  • Last login:May 07, 2016, 08:00:40 pm
  • I am a grumpy old man.
    • facebook.com/grumpyoldpenmaker2
Re: Mame console.
« Reply #80 on: June 09, 2015, 03:17:43 am »
Marquee panel installed and lit.
Linux, because Rock doesn't do windows.
Rock
Re: Mame console.
« Reply #81 on: June 10, 2015, 10:58:32 pm »
Monitor and bezel installed.
Rock
Re: Mame console.
« Reply #82 on: June 13, 2015, 10:42:51 pm »
After trying a few games I decided to install computer controlled servo motors to switch the joysticks between 4 way and 8 way mode. The last 3 LED clusters are now wired.
Rock
Re: Mame console.
« Reply #83 on: June 15, 2015, 12:42:46 am »
Added external USB ports. Trim plates to be added later.
Re: Mame console.
« Reply #84 on: June 15, 2015, 01:40:35 am »
Why so high?
Rock
Re: Mame console.
« Reply #85 on: June 15, 2015, 02:22:28 am »
Why so high?
A couple of reasons. The first being limited floor space in my shop. Lower limits how close I can set things next to the cabinet. The second is that those will be used for mainly for charging devices, leaving the top to be used as a shelf, and for hooking up my shop webcam. Thumb drives would go in the ones above the keyboard on the front.
Green Giant
Re: Mame console.
« Reply #86 on: June 15, 2015, 11:34:58 am »
Why so high?
Then wear will the beers go?
Toxic Arcade, my first build
Rock
Re: Mame console.
« Reply #87 on: June 15, 2015, 11:58:14 am »
[A couple of reasons. The first being limited floor space in my shop. Lower limits how close I can set things next to the cabinet. The second is that those will be used for mainly for charging devices, leaving the top to be used as a shelf, and for hooking up my shop webcam. Thumb drives would go in the ones above the keyboard on the front.
In the house, away from the power tools.  :laugh2:
Rock
Re: Mame console.
« Reply #88 on: June 16, 2015, 03:15:17 pm »
USB hub wiring complete and final test of ports.
Rock
Re: Mame console.
« Reply #89 on: June 17, 2015, 01:40:43 am »
While this is more software for the system, it is worth noting that now I can listen to MP3s  :applaud:
Rock
Re: Mame console.
« Reply #90 on: June 17, 2015, 10:33:06 pm »
USB faceplates added and computer secured
Rock
Re: Mame console.
« Reply #91 on: June 30, 2015, 10:02:39 pm »
Sorry, folks. This project is on hold for a bit while I recover from a heart attack.
vwalbridge
Re: Mame console.
« Reply #92 on: July 01, 2015, 12:03:33 am »
Holy moly man! Best wishes to you making a full recovery!
  • Last login:Today at 02:55:37 pm
Re: Mame console.
« Reply #93 on: July 01, 2015, 08:46:11 am »
 :o
Take it easy man! :cheers:
BGoulette
    • lazerjoose.com
Re: Mame console.
« Reply #94 on: July 01, 2015, 01:01:01 pm »
Holy smokes! I hope you make a full recovery, and soon!
Rock
Re: Mame console.
« Reply #95 on: July 07, 2015, 09:28:16 pm »
Thanks for the well wishes!
I did do a little on it tonight. I finished up the external network jack which was what I was working on when the heart attack started. The first picture is the hinge for the control console lock.
« Last Edit: July 13, 2015, 11:59:59 am by Rock »
Rock
Re: Mame console.
« Reply #96 on: August 05, 2015, 08:59:03 pm »
I hope to be back working on this project full swing after next week. I go in Monday for a second stent and should be as good as new after that.
