March 31, 2024, 03:08:21 pm
Added external USB ports. Trim plates to be added later.
Why so high?
Quote from: yotsuya on June 15, 2015, 01:40:35 amWhy so high?A couple of reasons. The first being limited floor space in my shop. Lower limits how close I can set things next to the cabinet. The second is that those will be used for mainly for charging devices, leaving the top to be used as a shelf, and for hooking up my shop webcam. Thumb drives would go in the ones above the keyboard on the front.
Quote from: Rock on June 15, 2015, 02:22:28 am[A couple of reasons. The first being limited floor space in my shop. Lower limits how close I can set things next to the cabinet. The second is that those will be used for mainly for charging devices, leaving the top to be used as a shelf, and for hooking up my shop webcam. Thumb drives would go in the ones above the keyboard on the front.Then wear will the beers go?
Sorry, folks. This project is on hold for a bit while I recover from a heart attack.
Holy smokes! I hope you make a full recovery, and soon!
Take it easy man!
Holy moly man! Best wishes to you making a full recovery!
