Main > Main Forum
Arcade games you can play with a Star Wars Yoke
leapinlew:
Right on Bobby!
Vocalitus:
Played another game last night on my star wars controller.
Steel Talons. Awesome game back in the day.
PL1:
Like Apache 3 (see reply #44 above), the SW yoke should be great for the cyclic (stick) control in Steel Talons.
- There is also an analog control axis for the collective (throttle/lift) and another analog control axis for the rudder pedals.
Seems like it would be hard to play properly without at least microswitch controls for the collective and rudder.
Yoke and two microswitch pedals should cover it all if you map:
- Cyclic X- and Y-axis to the yoke X- and Y-axis.
- Missile to the left yoke trigger.
- Gun to the right yoke trigger.
- Collective increase/decrease to the yoke right/left thumb buttons.
- Rudder right/left to the microswitch pedals.
If you have an analog pedal, map the collective to the pedal and map the rudder to the yoke thumb buttons. ;D
bobbyb13:
--- Quote from: PL1 on February 25, 2021, 05:43:18 am ---Like Apache 3 (see reply #44 above), the SW yoke should be great for the cyclic (stick) control in Steel Talons.
I need to keep an eye on this reply Scott because that is a brilliant idea for making that work. :cheers:
Especially since I already have a 2 pedal cluster stuck in the monstrosity build
Vocalitus:
I tried firefox last night on my Star Wars controller and I nearly seriously injured myself.
Not sure what is up with this game, safer to play it with a mouse.
