Main > Main Forum
The 2014 BYOAC User Choice Awards need your nominations!
Locke141:
--- Quote from: Le Chuck on January 03, 2015, 01:42:18 pm ---Hey LT, I think you're the first cat to ever have two builds in the same category get confirmed - and all within the first 24hrs of the nom thread opening. Griff had two builds in two categories last year IIRC but you're actually competing against yourself here. That's some damn fine craftsmanship and I think it is impressive as all hell. Not only do you crank out builds with a quickness you do it better than most so my hat is off to you man. Well done!
:applaud: :cheers:
yotsuya:
Louis, brother, I think you underestimate yourself. Yes, some of your early stuff was very janky. But you've gone leaps and bounds just learning from your process. For that, I'm glad you've been recognized.
Louis Tully:
Louis Tully:
ChanceKJ:
Yes but do those "feels" have an intricate and redundant pattern cut into the wood with a rotary tool, then filled in with ball point pen?
...because without that, they are nothing.
