Author Topic: A "Tully"-copy - Current status: Credit button question  (Read 25968 times)
JDFan
  • Last login:May 21, 2023, 04:07:42 pm
Re: A "Tully"-copy - Current status: Wiring done
« Reply #160 on: September 22, 2015, 06:53:40 pm »
hmmm, so where exactly is the point of the side pieces, missing one measurement unless I'm blind.
IIRC it was 10.5" for the back measurement ( from back edge 44.5" measure to top of 48" panel) --- It is listed in one of the build threads I'll see if I can find it and verify !!
Found it -- was the Depleted Uranium Build posts 6 and 8 ( http://forum.arcadecontrols.com/index.php/topic,142577.0.html ) and my math gave approx 10" but IIRC Louis later replied his was approx 10.5" but that 10" would work - and the top plate is 10" so if you want a small lip in the front you'll want to use 10.5" for that top side cut so it has the 1/2" lip above the 10" top panel in the front of the setup !
« Last Edit: September 22, 2015, 07:05:09 pm by JDFan »
BorgDog
« Reply #161 on: September 22, 2015, 07:14:28 pm »
My Projects:
johnrt
« Reply #162 on: October 20, 2015, 03:01:42 pm »
I'm currently sanding and filling the Nintendo cab. During breaks I play on my "Tullly". Tonight I set a new record on Arkanoid - Revenge of DoH. For information: I'm not cheating. All DIP switches are set to default.
And btw: This cab is as good as finished. It just needs some artwork. I'm planning on ordering that together with the art for my Nintendo cab.
« Last Edit: October 20, 2015, 03:03:40 pm by johnrt »
johnrt
Re: A "Tully"-copy - Current status: Just missing artwork
« Reply #163 on: October 28, 2015, 06:18:22 pm »
Today I received some credit buttons from a french dealer (http://www.joystick-arcade.com/gb/20-boutons-monnayeur-factice-simulation-monnayeur). These seems to be in good quality. They are lit, although with an old fasion 12V lightbulb. However I had some LED replacements I ordered earlier this year for the dashboard on my motorcycle. These fits in these buttons and are 12V also. I also got one button for free since I was their first norwegian customer!  :lol
In photoshop I'm playing around trying to find the most optimal place for these buttons. What do you guys think, like this?
Or like this?
Or like this:
Or maybe like this:
« Last Edit: October 28, 2015, 06:46:56 pm by johnrt »
yamatetsu
  • Last login:Yesterday at 06:03:51 pm
  • Just because.
Re: A "Tully"-copy - Current status: Credit button question
« Reply #164 on: October 28, 2015, 07:08:32 pm »
From an aesthetic point of view, I'd say the last one. However, that probably is the worst one for functionality, as the buttons are too far down. A compromise would be the first one.
johnrt
« Reply #165 on: October 28, 2015, 07:16:21 pm »
I kind of agree. However, on the Nintendo cab the coin slot is also way down there.
If someone has another suggestion, the photoshop file is available here:
http://www.379009.net/jamma-cab/photoshop/tully_creditbutton.zip
BGoulette
  • Last login:March 21, 2024, 08:17:49 pm
    • lazerjoose.com
« Reply #166 on: October 28, 2015, 08:08:08 pm »
 :o
I see faces in everything :( It's a sickness, really.
Edit: to contribute, I agree with what's been stated above: I like the inline look, but functionally, not sure how annoying that might be. Although it would certainly be an incentive not to die! ("Well, I was going to add another credit, but the button is all the way down there....") ;-)
  • Last login:February 15, 2024, 07:31:21 pm
« Reply #167 on: October 28, 2015, 08:15:04 pm »
Here are a couple suggestions:
Not everything needs to be symmetrical, and having them closer to the marquee within better reach would be nice. I wouldn't go any lower than what you'd see on an Asteroids Cabaret.
A has them on the right side, but it could be on the left side too.
B is for the symmetrical aspect, if you're set on keeping things that way.  It's not my first choice, but I figured to include it as another option to consider. Keeps P1 Coin and P2 Coin separate though... but personally I don't really like it.
ChanceKJ
« Reply #168 on: October 28, 2015, 11:32:53 pm »
« Last Edit: March 19, 2021, 04:04:36 am by ChanceKJ »
  • Last login:Today at 12:22:26 am
« Reply #169 on: October 28, 2015, 11:38:34 pm »
Hands down Opt's Option "A"
Ditto.
  • Last login:February 19, 2024, 12:40:25 pm
« Reply #170 on: October 28, 2015, 11:50:31 pm »
Second thirded
ChanceKJ
« Reply #171 on: October 29, 2015, 12:10:45 am »
« Last Edit: March 19, 2021, 04:04:14 am by ChanceKJ »
« Reply #172 on: October 29, 2015, 12:54:51 am »
Chance is right, by making the rejects symmetrical you got yourself a Cylon or a gas mask wearing lemur.
johnrt
« Reply #173 on: October 29, 2015, 04:45:19 am »
You can use your knee!  :lol
And I agree about that speaker grill being a little misplaced. But it's too late to do anything about that now. The front is actually better looking WITHOUT credit buttons. Maybe I should place the credit buttons on the bezel instead?
ChanceKJ
« Reply #174 on: October 29, 2015, 05:45:54 am »
« Last Edit: March 19, 2021, 03:08:39 am by ChanceKJ »
  • Last login:Yesterday at 06:49:25 am
« Reply #175 on: October 29, 2015, 10:03:26 am »
I think the coin buttons need a plate behind them.
Either metal or ABS plastic.
If it were me, I'd make a fake coin door where the speaker hole currently is and then mount the speaker elsewhere.
I'd do small metal plates on top a large black plate to mimic the original donkey kong coin door style.
It doesn't have to be a exact replica.  I think your buttons mounted on top of metal rectangles mounted on top of a black square would look good.
EDIT: check out metal access panels at your local hardware store.  They aren't that expensive and would make a convincing coin door that actually opens.
Here is a fake 1-slot setup I made.
The coin return is actually a gutted square button with the top lens painted black and glued in backwards.
Not perfect, but my whole shtick with that cab was using what I had laying around and not spending any money.
« Last Edit: October 29, 2015, 10:15:15 am by BadMouth »
johnrt
« Reply #176 on: December 08, 2015, 05:42:29 pm »
I decided to ditch the coin buttons and go for the CoinUP. I just want to be done with this cab, so I can play it!
ChanceKJ
« Reply #177 on: December 08, 2015, 05:53:12 pm »
« Last Edit: March 19, 2021, 03:27:31 am by ChanceKJ »
johnrt
« Reply #178 on: December 08, 2015, 06:01:38 pm »
...you've been watching John's videos, haven't you :P
Yes, but I knew about that one anyway. :-)
I just got an answer from Adam confirming he'll send me a couple of those. (He didn't normally ship internationally)
« Reply #179 on: December 08, 2015, 06:06:13 pm »
Totally forgot about those. Thanks for posting this.
