Main > Main Forum
Jamma help
jaharr01:
Okay I have a few more questions. I got it wired up and it's working. I was wondering about setting up the games. Some of the games are grayed out and unplayable. I was reading in the manual it was talking about dip switches. Are there dip switches that are changed on the board and in the set up menu also? I never read anything about enabling games.Are there individual dip switches in the menu that enable each game along with setting up difficulty levels and such? I just wanted to make sure that there are no physical switches I need to flip on the actual board or do I do everything from the service menu. The monitor is in the correct position and i have a test and a service button.
Ken Layton:
In the software menu you can enable/disable individual games.
JDFan:
Most of the current boards (YMMV) have a single 4 bank dip switch (physical) on the PCB that controls Screen Orientation, Display Mode, High Score Saver, and System Mode (Normal,test Modes)
The rest of the dip switches are software switches not physical - these are set by going in to test mode (either by using the Dip switch (physical) to enter test mode or booting with the Test button pressed (the various menus and settings are in the Manual - ( LINK http://www.koceraj.hu/Koceraj/Mi_ez_files/60-in-1_Arcade_Manual.pdf ) on pages 3 and 4.
jaharr01:
Got it. Actually very easy to set up. It would be nice to have some of those game adjustments such as amount of lives,free play, and level unlocking in mame. Thanks for the help
JDFan:
--- Quote from: jaharr01 on December 23, 2014, 10:55:38 pm ---Got it. Actually very easy to set up. It would be nice to have some of those game adjustments such as amount of lives,free play, and level unlocking in mame. Thanks for the help
THose are available just like in MAME -- Once you get the system setup - rather than pressing the setup button to exit - press the Test SW button to enter the DipSW setup for each game !! (IT is on page 4 of the manual I posted earlier for you !! :dunno ) ::)
And the available settings for each game are pages 11 - 32 of the same (you might have missed them since it first goes through the screenshots of the games on pages 5-10 ! )
