Main > Main Forum
White (NOT Off-White) Player Start Buttons?
Slippyblade:
Not sure where your existing "white" buttons came from if the ones linked are "off-white" to you. I've never seen whiter than those linked.
newoski:
Interesting...
I'll have to snap a few pics and post them... I've heard the Ultimarcs are standard white, so I've ordered a pair and will post back with my results as soon as I receive them.
(I promise I'm not crazy)
Louis Tully:
RandyT:
--- Quote from: Slippyblade on December 09, 2014, 07:00:49 pm ---Not sure where your existing "white" buttons came from if the ones linked are "off-white" to you. I've never seen whiter than those linked.
The situation is that pretty much all of the common "white" buttons out there aren't perfectly white, so there's not much difference between those and the 1P 2P buttons. I believe the OP has our white CLASSX buttons, and they are modeled after the white of the buttons on early arcade machines. They very white (like snow). Regular white buttons actually look a bit yellowish, or dull, next to the CLASSX white.
newoski:
100% correct Randy
That's the best way I can describe the difference -- camera can't pick it up. The CLASSX are white, while the others have a dingy yellow tint to them. They look good on their own, but side by side, the non-CLASSX look dingy
