Main > Main Forum
39" Screen in Cab? Need Opinons
Pages: << < (4/5) > >>
MTPPC:
Mount the 39" vertical and make the horizontal games maintain aspect ration. Then use Hybrid View tables for VP and you will have an awesome setup:
http://vpuniverse.com/forums/files/category/65-hybrid-view-tables-hv/
zaltec:
If you want to wait a few months (late spring likely), you can see how my 40" horizontal build turns out... my WAF depends on me using our current 40" tv in the build (it's a 4P anyway, so the cab will be closer to the CP width) and replacing it with a newer, larger tv for the living room... I figure it'll be my first build, so I can get the WAF on it and work on my skills, and then eventually replace it with a rotating 27" or something for v2.
I am however really trying to avoid the looks of the Arcades R Fun builds, I find them horrible looking for some reason (worse so than most typical "fugly" builds)... I'd like to do more of a "widebody" Flynn's or something similar with more classic lines.
yotsuya:
--- Quote from: zaltec on December 05, 2014, 11:20:06 pm ---If you want to wait a few months (late spring likely), you can see how my 40" horizontal build turns out... my WAF depends on me using our current 40" tv in the build (it's a 4P anyway, so the cab will be closer to the CP width) and replacing it with a newer, larger tv for the living room... I figure it'll be my first build, so I can get the WAF on it and work on my skills, and then eventually replace it with a rotating 27" or something for v2.
What the hell's WAF?  :cheers:
P.S. Arcades R Fun do indeed suck.
MTPPC:
WAF = Wife Acceptance Factor
yotsuya:
--- Quote from: MTPPC on December 05, 2014, 11:51:39 pm ---WAF = Wife Acceptance Factor
Oh, I see. Thank God I don't have to worry about that. My wife doesn't care how many buttons my panels have or anything like that. As long as she can play our Tempest, I can do whatever I want.
Go to full version
