Author Topic: Trying to identify these spinners I'm thiking of buying.  (Read 1394 times)
sin360
  • Last login:May 11, 2023, 11:12:23 am
« on: November 29, 2014, 02:12:28 pm »
Does anyone know what kind of spinners are in this picture. I'm thinking of buying them; are they any good? I'm going to use them in my cabinet which is 3/4 inch. How much is a decent offer for these?
« Last Edit: November 29, 2014, 02:21:34 pm by sin360 »
NickG
  • Last login:September 26, 2022, 05:25:23 am
  • Dig.
    • My Projects Page
Re: Trying to identify these spinners I'm thiking of buying.
« Reply #1 on: November 30, 2014, 05:35:01 am »
Those look like GroovyGameGear original TurboTwist.
  • Last login:Yesterday at 09:39:49 pm
sin360
« Reply #3 on: November 30, 2014, 08:46:57 am »
Thanks for the info. So how much would you offer someone for 2 of these? Since they are only selling them as a set. Well I offered him $35 for one seen if he sells me one. That's half of what they used to cost new. Hopefully he parts with one since I don't really need two of them.
« Last Edit: November 30, 2014, 08:56:55 am by sin360 »
lamprey
« Reply #4 on: December 03, 2014, 01:10:24 pm »
How much does he want for a set? Assuming they work for your application, then I'd think $35-40 for the pair is fair. But, I'd rather get the new version of the turbo twist just to avoid possible mounting issues, plus the new version is really easy to install. My $0.02.
sin360
« Reply #5 on: December 03, 2014, 01:50:22 pm »
I offered him $35 for one, but he doesn't want to separate them and would rather have $65 for both. For $65 I think I'm better off just spending a little extra and getting the turbo twist 2. I asked someone on here to see if they wanted to split the cost since they where looking for a spinner, but no worries. I'm finishing up this spinner I'm making. So if that works I'll use  till I'll buy a turbo twist 2.
Louis Tully
« Reply #6 on: December 03, 2014, 03:53:35 pm »
« Last Edit: February 12, 2015, 06:23:23 pm by Louis Tully »
sin360
« Reply #7 on: December 03, 2014, 08:10:30 pm »
It's a vcr/mouse hack that I found online. Credits go to axeman.  Here are some pictures of how it's coming along. The flat piece is just something I had laying around the shop that wasn't going to be too hard to cut through or soft that it will break. I used this 3M 2 part compound to glue the flat piece to the vcr head. I didn't want to screw it because I wanted to lay flat on the bottom of the control panel. Need less to say I've used that compound on fuel tanks before for emergency purposes till a new one came in. So I know it's a strong bond after both surfaces are scuffed up a little.
The coupler is 1/4-20 which I drill out half of it just a hair bigger so I can press it on the shaft of the vcr head. On the other end I'm going to be using 1/4 inch threaded rod since 1/4 inch is the size of all the spinner knobs available to my knowledge.  The knob I'm using is this which I'm getting from Mc Master Carr.
http://www.mcmaster.com/#7354K15
Now I'm just trying to figure out a bracket to hold the mouse pcb in place. I was just testing it holding the pcb and spinning the wheel around. It was moving, but real slow so if anyone has any suggestions on what setting I need to adjust that would be great.
I had everything except knob $5.59 , couplers $3 and I got the encoder wheel printed for like $8 at a local shop. They printed 4 to a sheet. It was cheaper then buying or finding some transparent film. I forgot to mention I used hot glue to hold the cd center holder in place.
Here is the Axeman's site where I got the info from.
http://www.axe-man.org/arcade-spinner-2/?lang=en
Here are some WIP pitures.
