Author Topic: 4 player setup with XinMo controllers?  (Read 2342 times)
tschneider
  • Last login:December 28, 2014, 01:24:13 pm
« on: November 28, 2014, 04:09:06 pm »
Has anyone tried to use 2 Xin-Mo dual controllers in 4-player cab?  I am converting a 2-player MAME32 cab to 4-player, and just got another Xin-Mo controller based on some posts I read, which indicated this as a viable solution.  However, MAME32 won't recognize the second controller.  The controller shows up in Windows device manager (its a WinXP machine), but when I try to assign a button in the MAME32 tab settings, I can't get it to recognize anything from the second controller.  Any advice?
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
Re: 4 player setup with XinMo controllers?
« Reply #1 on: November 28, 2014, 11:03:49 pm »
It also depends on what front end you want to use.  If you plan on using Hyperspin, Xinmos will not work in the menu at all.
thomas_surles
  • Last login:June 19, 2023, 07:20:00 pm
« Reply #2 on: November 30, 2014, 09:08:42 am »
I use xin mo with mame 32 and maximus arcade. Joy 2 key is your best friend. Set it up and put it in your startup folder.
tschneider
« Reply #3 on: December 01, 2014, 01:44:23 pm »
I just found out that one of my two Xin-Mo controllers had a problem, in that button 6 always appeared ON.  Problem with the controller chip.  Good chance that this was my problem.  I'm waiting for a replacement board now -- I'll provide an update when it gets here.
tschneider
« Reply #4 on: December 18, 2014, 02:33:06 pm »
OK I got the new controller, and I can access players 3 and 4 now, though I did have to change some things in the stock MAME32 UI settings.  Initially, when I plugged in the new controller, MAME still wouldn't recognize players 3 and 4.  However, I was playing around in the MAME32 UI, and found that in Options->Default Game Properties, on the controllers tab, it showed 4 dropdown boxes for the different game controllers, but only the first two had active selections.  I enabled controllers 3 and 4, and now the MAME tab settings would recognize the players 3 and 4 controls.  Thanks thomas_surles for the suggestion of joy2key -- I wound up using that to map my player 1 coin and start buttons to "O" and "K" so that I could run the games that say "press OK to continue", without hooking up an actual keyboard.
  • Last login:October 20, 2023, 11:39:06 pm
« Reply #5 on: December 18, 2014, 03:51:31 pm »
More specifically, Hyperspin doesn't work well with Joysticks.  It was designed for use with a keyboard.
