Author Topic: Control Panel 101: Where do you buy the metal to make a CP from?  (Read 2064 times)
Generic Eric
  • Last login:March 05, 2024, 09:02:23 am
Where does someone shop to find metal for making a CP from?
How thick are control panels typically?
shponglefan
Re: Control Panel 101: Where do you buy the metal to make a CP from?
« Reply #1 on: November 23, 2014, 08:36:37 pm »
OOC, are you looking to design/build from scratch?  Or are you looking for something prefabricated?
Generic Eric
« Reply #2 on: November 23, 2014, 10:02:39 pm »
Just want to fold a rectangle for now.  I recall a recent post where someone suggested it could be done in a garage.
thomas_surles
  • Last login:June 19, 2023, 07:20:00 pm
« Reply #3 on: November 24, 2014, 12:11:57 am »
I know you can buy sheet metal at ace hardware. Might be too thin though, but look around at your local hardware store(not home depot/Lowe's)
Louis Tully
« Reply #4 on: November 24, 2014, 03:33:46 am »
« Last Edit: February 12, 2015, 06:15:39 pm by Louis Tully »
mgb
  • Last login:February 21, 2024, 06:18:13 pm
  • North East, US
« Reply #5 on: November 24, 2014, 07:06:34 am »
I believe a metal control panel on a comercial machine would be 16 gauge.
You can get it at Home Depot and lowes.
It will be a bit harder to bend than something like 22 though
  • Last login:April 28, 2024, 12:59:28 pm
« Reply #6 on: November 24, 2014, 09:18:34 am »
I use 16 gauge for my panels, but I have access to a full fabrication setup. I don't think I could do it properly otherwise.
nitrogen_widget
  • Last login:March 30, 2024, 09:10:09 am
« Reply #7 on: November 24, 2014, 11:07:51 am »
We have one of these.
http://www.harborfreight.com/36-inch-metal-brake-with-stand-91012.html
but so far have only used it for car floor panels & other stuff that doesn't need to be pretty.
What kinds of bends would be needed and what gauge sheet metal to make it rigid enough so you don't need any wood underneath?
« Reply #8 on: November 24, 2014, 11:50:50 am »
I've used something pretty similar in our metal shop. It's great for simple panels and 90 bends. Anything more than that is iffy, though.
Ken Layton
  • Guru
  • Technician
« Reply #9 on: November 24, 2014, 12:00:28 pm »
Look in the Yellow Pages under these categories:
Welding shops/supplies
Metal Fabricators
Steel Distributors
I've also seen both Home Depot and Lowe's stock some decent sized pieces of sheet metal in the hardware section.
  • Last login:February 19, 2024, 12:40:25 pm
« Reply #10 on: November 24, 2014, 12:37:59 pm »
Got any real estate or street signs laying around? I have both and have often wondered how they would turn out as metal panels.  Also we have that Harbor Freight Metal Brake in our shop and its pretty good for the price.
nitrogen_widget
« Reply #11 on: November 25, 2014, 09:46:25 am »
Galvanized street signs from the 90's made really really good floor pans.
I've heard.
I'm looking up diagrams or plans for metal boxes.
I'd just need a box that's only a few inches deep for rigidity for a bar-top panel. correct?
I'd want some plywood under a flat sheets of metal for a full sized cab I'd think though?
