Main > Main Forum
[SOLVED] Need some guidance with a batch file. Help a dummy?
<< < (2/2)
rockyrocket:
Sweet, get building!.
Thinking some more on this if your 3 game launch buttons were for example A,B and Shift then button combo`s can be used to shut down or reboot as well.
--- Code: ---+A::Shutdown, 2 ;Reboot
+B::Shutdown, 1 ;Shutdown
--- End code ---
You really would have a bare metal system then.
Louis Tully:
rockyrocket:
No worries, glad to help.
Put a shortcut to one of your Bat`s into your start up folder and you should just boot straight into a game and never see the desktop.
Now get building  ;D .
Edit - Glad you have no command window pop up, on my test bed (Win7-64) I do get a visable window so had to use that VBS trick linked to above.
It is messy as AHK calls a VBS that stars a Bat, but no window is seen - the VBS looks like this....
--- Code: ---Set WshShell = CreateObject("WScript.Shell")
WshShell.Run chr(34) & "C:\Users\Mame seven\Desktop\AAE Bat`s\AsteroidsDelux.bat" & Chr(34), 0
Set WshShell = Nothing
--- End code ---
And now the AHK is this...
--- Code: ---#NoEnv
SetWorkingDir %A_ScriptDir%
a::
Send {Esc Down}, Send {Esc Up}
Sleep, 1000
Run, %A_ScriptDir%\Astdelux.vbs
return
b::
Sleep, 1000
Run, %A_ScriptDir%\BattleZonePlus.vbs
return
--- End code ---
Louis Tully:
rockyrocket:
Looks good buddy!.
You ninja`ed a response in whilst I was editing my last post  ;D .
A funky select sound may be sweet too?
I use the attached photon sound in one of my cabs - just drop it or any other sound into the same dir as the AHK file and then use..
--- Code: ---y::
SoundPlay, launch.mp3
Send {Esc Down}, Send {Esc Up} ;quits aae
Sleep, 1000
Run, C:\ADCabBatScripts\aaeAsteroids.bat
return
u::
Sleep, 1000
Run, C:\ADCabBatScripts\aaeAsteroidsDeluxe.bat
return
i::
Sleep, 1000
Run, C:\ADCabBatScripts\aaeArmorAttack.bat
return
--- End code ---
You could even use a different sound for each game?.
Navigation
Message Index
Previous page
Go to full version
