Main > Main Forum
Will this cp layout double as a "finger-meat" grinder?!
Le Chuck:
Pop-up spinner: Go to the boat store and buy two pop-up cleats
Break off the tops and and weld on a base panel and a top panel. Mount spinner through top panel. Ensure mounting plate at proper height so spinner top flush with CP. Doneskies.
dkersten:
Gonna a lot of depth to do a popup, and a lot of area if you used a plate and popped the plate up. Cool idea though. Well, maybe not with a wheel, you would be pushing it down all the time. Would need a dust washer with felt on it to keep from grinding your art off the CP surface.
Would be cool though..
drventure:
--- Quote from: Le Chuck on August 28, 2014, 10:51:30 pm ---Pop-up spinner: Go to the boat store and buy two pop-up cleats
That's exactly the kind of mechanism I was looking for. Heavy duty, pretty straightforward to hack.
Very Nice :applaud:
zanna5910:
Depending on what joystick you get, you may have issues wiring all the switches for the P1 joystick being that tight to the wall.
BGoulette:
Hmm. I was considering either a ServoStik or a U360 for P1. My hope was that a U360 wouldn't cause any issues, and the connections on a ServoStik looked like they'd fit, but if not, I think I could route out a small pocket on the side of that wall. Good observation. Thanks!
