Author Topic: Building from the ground up - Hardware Advice Request  (Read 6700 times)
TorgoHiggins
  • Last login:September 12, 2014, 01:52:49 am
  • Showers anyone?
« on: August 15, 2014, 12:47:15 am »
Salutations, folks.
Heaven help me, I'm going to try building a small cab. I know my way around pc parts a little bit, and zero woodworking skills. I DO, however, have access to all the necessary tools and workshop space, as well as expertise to tap for general construction advice and help. The goal, such as it could be called, is to build something that looks decent for as cheaply as possible (you know, as opposed to building something that looks like crap for as much money as possible). This is as much about doing and learning as it is about wanting an arcade cabinet, perhaps moreso. The tentative goal is a small-ish bartop. I want the screen to be a decent size, but probably no bigger then 17". Smaller/cheaper would be better. It must be LCD, for weight considerations if nothing else.
Speaking of, I live in Hawaii, so size/weight of parts and shipping cost are a huge deal. Always. All the time.
But before I can even think about the outside, I have to consider the innards. I picked up an old Jetway Mini-ITX board on the cheap. It comes with an embedded, passively cooled 1.2ghz processor; It needn't be powerful, just functional. If all it does it run an old NES emulator I'll be happy with it. The trouble is, I'm not 100% sure where to go from there. I've never put together a pc from scratch, so I'm driving a little blind here. I know I still need:
- A power supply
- RAM
- Hard Drive
- Some sort of removable media (I have a usb cd/dvd drive on the way)
Does this more or less complete a list for barebones PC hardware? It sounds right, but again, this is uncharted territory for me. Furthermore, anyone have recommendations on power supply? I see lots of voltages and numbers, stuff with fans, PicoPSUs for mini-itx boards that DON'T have fans. It's a little intimidating. What do I need, and moreover, what do I want?
For the arcade controls themselves I was considering simply springing for the X-Arcade DIY kit, since it seems straightforward and should be relatively free of any compatibility issues.
A few other notes:
- I will be installing WinXP Home on this system.
- The specs on the motherboard.
- I'm as yet undecided if it's going to be one or two players.
- The smaller, cooler, and less power consumed the better.
Any advice is appreciated. Hearty laughs at my ignorance will be less so, but understandable. :) Thanks!
dkersten
Re: Building from the ground up - Hardware Advice Request
« Reply #1 on: August 15, 2014, 01:21:00 am »
I am sure others will offer up all kinds of good information, but I will throw in a couple things to think about:
First, you may find you have better luck with older builds of mame when running that setup.  Some people say that even going back only as far as .147 gives something like 20-30% improvement in performance on many games over the current .154.. I haven't experimented myself because I am not using a slower processor, but it is certainly worth looking into...
Before building your controls, I would spend some time setting up mame on the computer, and play some games to see what you really want out of it.  Ideally, build your game list and then go from there.  You might find that you really want a solid 4-way joystick, or that you only care about 3 buttons and not 6 or 8.  You might find you really want a trackball or spinner or both.  You might find that you don't care about simultaneous 2 player games, and can get away with a single player control panel.
For that motherboard, unless you are putting it in a case that has a fan, I would install a fan to blow some air on it.  Once cooped up in that cabinet, without active cooling on the processor, it might start to get rather warm.  A basic 120mm fan running at 5v should be more than enough to keep it cool.  Just remember to put vents at the top and bottom of the cabinet so the heat can escape and pull in cool air in the process.
I am sure others will comment on the x-arcade controller.  If you are going to play any vs. fighters, I would listen to the advice you will get.  Also read the wiki, it is very valuable when just getting started.
Finally, even as cheap as you can keep it, you will get nickel and dimed on this, so pay attention to your hardware store runs, it adds up fast.  My first cab had a $1700 budget and I am at around $2600 now.. doesn't take long.
Good luck!
  • Last login:Today at 12:55:42 am
« Reply #2 on: August 15, 2014, 01:57:33 am »
Welcome aboard, TorgoHiggins.   ;D
You may want to read the FAQ to help you work through the design process and identify many of the "unknown unknown" factors. (a.k.a. "I need to know how to do what to make this cab look/work right??"  :lol)
For an overview of the woodworking skills needed to build a cab, check out this wiki entry condensed from Ond's Main Forum sticky thread.
On the subject of choosing controls and hardware, you might want to read up on the "6-button USB limit" of the X-Arcade encoder.
There is a workaround for that limit mentioned here, but you still have separate grounds for each connector which adds complexity to the wiring.   :dunno
Take your time researching and configuring the software like Dkersten mentioned and planning things out before you start ordering parts since you'll almost certainly end up ordering from multiple vendors.
Make a bookmark folder for threads that mention useful info and vendors/products that look promising.
Be sure to check out Ultimarc, GroovyGameGear, Paradise Arcade Shop in Waimanalo, and the many other vendors you'll find mentioned in various build threads.
Andy (AndyWarne), Randy (RandyT), and Bryan (armi0024) -- the respective proprietors of these three businesses -- are regulars around here on the BYOAC Forums.
« Last Edit: August 15, 2014, 02:00:10 am by PL1 »
TorgoHiggins
  • Showers anyone?
« Reply #3 on: August 16, 2014, 12:44:35 am »
Thanks for the tips guys!
I've decided I'm going to put the system in a case of it's own. I found a nice compact mini-itx case with lots of ventilation and a power supply for forty bucks. As nice as the idea of mounting the hardware is, this very neatly solves a lot of the power issues and some of the ventilation issues, though there will still be the matter of cutting some vents into the cab itself. Plus now I can more easily get the system setup and running before I start work on the cab itself. :) I picked up a cheap stick-o-ram as well. I think all that leaves is a hard drive and maybe some various cables.
Is going with a solid state drive worth the expense? The going rate for an 80gb on ebay seems to be between 30-40 dollars, which sounds decent enough. The case I'm getting has space for 3.5" or 2.5" hard discs though, which I wasn't originally planning on. I might just save the bucks and buy a small 3.5" drive.
TorgoHiggins
  • Showers anyone?
« Reply #4 on: August 18, 2014, 06:22:20 pm »
So while I'm still waiting on the pc bits to arrive, I'm starting to noodle the cabinet side of things. The main thing I'm really roiling over is the screen. I know I want a flat-panel, but man I'm limited on options. Getting a screen second-hand on ebay is pretty much not an option: Most don't ship to Hawaii, and those that do will shaft me with parcel post (six week shipping time and who knows what kind of arrival condition). Amazon has a couple Acer 4:3 models with free shipping, but the starting rate is $100 for a 17". I'm willing to spend a hundred bucks (which I realize compared to a proper arcade monitor is still cheaping out), but if I can avoid it I will.
Out of curiousity, is there anyway to buy a laptop screen and use that? For example: There's a 15.4" wxga screen for $52~. The screen size is actually pretty close to what I had in mind for a first project, and the price is right. Are there options out there to hook something like this up?
« Last Edit: August 18, 2014, 06:23:55 pm by TorgoHiggins »
« Reply #5 on: August 18, 2014, 06:37:37 pm »
Check Craigslist for local deals.
Also you may want to look into this thread for coupon codes for off-lease monitors and computers from Arrow Direct -- not sure if their shipping costs to Hawaii are reasonable, though.   :dunno
JDFan
  • Last login:May 21, 2023, 04:07:42 pm
« Reply #6 on: August 18, 2014, 06:44:20 pm »
Looks like they ship to HI for the same flat rate as the rest of the US $8.99 !
TorgoHiggins
  • Showers anyone?
« Reply #7 on: August 18, 2014, 06:53:05 pm »
Hot dang, thanks for that link, PL1. They'll ship me a monitor for less then ten bucks! :applaud: I'll take a b-grade refurb for that price fo sho.
This project just got a lot cheaper. I was prepared for the screen to be the most expensive component!
dkersten
« Reply #8 on: August 18, 2014, 06:53:49 pm »
You would have a heck of a headache trying to hack a laptop monitor to work in a cab.. not worth the effort.
I wouldn't go smaller than 19" personally, a 17 or 15 looks tiny in even a small cab.
I have 6 4:3 19's sitting on my shelf I would sell for $40 each if you can find cheap shipping from 59101.  They won't fit in a flat rate box though as far as I can tell.  Sounds like that Arrow Direct place would be better for you anyway, especially if they can do the $9 flat rate box.
TorgoHiggins
  • Showers anyone?
« Reply #9 on: August 18, 2014, 07:02:36 pm »
I was honestly starting to think that myself. I have a 15" as a second monitor on my system, and well... yeah.
JDFan
« Reply #10 on: August 18, 2014, 07:03:31 pm »
Just remember to put in the Coupon code "Dealnews" -- right now it gets you half off the already 30% off on monitors and systems so worth the effort to type in !!!!
They have an IPS panel 20" Dell 2001FP that's a 4:3 20" monitor for $58 - $29 with the code + $9 shipping makes it about $40 for a good IPS panel flatscreen with 178 degree viewing angles and great picture quality.
« Last Edit: August 18, 2014, 07:09:36 pm by JDFan »
TorgoHiggins
  • Showers anyone?
« Reply #11 on: August 18, 2014, 07:24:45 pm »
Thanks for the recommendation! I'll have to nab an adapter since my motherboard only has vga, but that's cheap enough to pick up.
edit: never mind, reread the spec sheet and saw it does have vga input. I'm good to go. ;D
« Last Edit: August 18, 2014, 07:27:18 pm by TorgoHiggins »
bulbousbeard
  • Last login:August 25, 2015, 11:58:25 pm
« Reply #12 on: August 18, 2014, 11:55:25 pm »
Don't buy one of those crappy old 4:3 LCDs. Just get the new 27" G-Sync monitor that's coming out THIS WEEK.
Do you REALLY want to play every game at the wrong speed or with stuttering? G-Sync is the only acceptable LCD solution right now.
  • Last login:April 28, 2024, 12:59:28 pm
« Reply #13 on: August 19, 2014, 12:59:52 am »
He said he wants to make a small cabinet.
Oh, and there's nothing wrong with a 4:3. I'd do a 19" or 20.1" all day long over a widescreen.
dkersten
« Reply #14 on: August 19, 2014, 01:21:22 am »
Measure a 19" 4:3 compared to a 24" wide screen.. they are nearly identical for playable size in any mame game.
Is the asus ROG g-sync coming out finally?  Great idea but aside from FPS games, not going to make a single bit of difference, lol.  I was going to go with it, and if it had come out 4 months ago I would already have it for my main gaming PC.. but priorities change, and they missed out on one sale (and I imagine a few others who had time to second guess a $700 27" monitor)..
« Reply #15 on: August 19, 2014, 01:28:45 am »
Everything I want to play fits perfectly on a 4:3. Everything else is wasted space for the money. I don't play PC games or widescreen games on my cabs, so why spend the extra money when I can get a perfectly working 4:3 for under $50?  :dunno
shponglefan
« Reply #16 on: August 19, 2014, 07:53:41 am »
4:3 LCD monitors are fine for gaming, especially if the goal is older non-widescreen console/arcade games.   I've used old Dell and Samsung monitors and they've worked out well.  You can sometimes snag them for free from businesses recycling old monitors.
bulbousbeard
« Reply #17 on: August 19, 2014, 10:24:59 am »
Seriously, are you incapable of reading?
It isn't about the size.
Repeat with me: A ---smurfy--- STANDARD LCD WILL STUTTER IN BASICALLY EVERY GAME IN MAME BECAUSE BASICALLY EVERY GAME IN MAME DOESN'T RUN AT 60hz.
So you think that stuttering is fine? You like stuttering or tearing? Sounds like a great arcade experience. You think that running every game glass smooth at its native refresh rate doesn't make a difference? Stop spreadi1ng misinformation when you have no idea what you're talking about.
G-Sync is the ONLY way I'd use an LCD in a cabinet. Otherwise, a CRT with GroovyMAME is the answer. It is NOT acceptable to run games at the wrong refresh rate with stuttering.
GEEZUS
Oh, and it isn't 24". It's 27".
AND you're completely ignoring the fact that the only way an LCD is going to look good is by using HLSL at a very high resolution, which a ---smurfy--- old 4:3 is incapable of running at.
I'm not sure if it's ignorance, cheapness, or both.
« Last Edit: August 19, 2014, 10:28:27 am by bulbousbeard »
« Reply #18 on: August 19, 2014, 10:47:12 am »
Talk about ignorance... you can tweak your individual game .ini files to eliminate tearing. I do it all the time, especially with side-scrollers. I also don't run HLSL because, quite frankly, I don't feel like I need to fake myself out and pretend that I'm using a CRT when I'm not. If I want to use a CRT, I'll use a CRT.
Yeah, I know, you wrote an super awesome HD front end based on the best game EVAR for your widescreen 70 inch G-FORCE Ultra-plasma LCD....blah blah blah. Meh. Some people just like playing games, dude.
SavannahLion
« Reply #19 on: August 19, 2014, 11:08:09 am »
GEEZUS
Sorry.. I don't understand ass... can someone translate?
Seriously, you're not going to convince anyone with an ass attitude like that. For the $1000 or more investment required for the monitor plus compatible video card, I can build an entire MAME system from the ground up WITH a true arcade monitor.
Sorry.....
bulbousbeard
« Reply #20 on: August 19, 2014, 11:14:44 am »
No, you can't "tweak" your way out of it. You have three options with a 60hz LCD:
1) Run the game with V-Sync on at its native refresh rate and get stuttering.
2) Run the game with V-Sync off at its native refresh rate and get tearing.
3) Force the game to run at 60hz and deal with the game running at the wrong speed (too fast or too slow), the sound being at the wrong pitch, and occasionally garbled sound.
You can do things with a high resolution LCD that you can't do with an arcade monitor. Playing Ultra Street Fighter IV at 1440p is one of them.
Running every game at the same resolution so your cabinet doesn't WIG OUT every time it has to change resolutions is another one.
MAME with good HLSL settings looks better on an LCD than MAME without HLSL. Period.
« Last Edit: August 19, 2014, 11:20:57 am by bulbousbeard »
bulbousbeard
« Reply #21 on: August 19, 2014, 11:16:09 am »
Also, I don't really consider the extra horizontal real estate on 16:9 monitors "wasted" when you can use it to include some of awesome bezel art that games had.
https://436e85e1-a-62cb3a1a-s-sites.googlegroups.com/site/bigbluefrontend/guhguh.png
Yeah!
Yeeeeaaaaahh!
cools
  • Last login:March 11, 2024, 02:59:06 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
« Reply #22 on: August 19, 2014, 11:30:36 am »
Option 3 using GroovyMAME (without CRT_Emudriver) and HLSL (http://wiki.arcadeotaku.com/w/File:Mame_hlsl_jezze_cools.zip) works pretty well, it's what I use on my laptop for testing. Better than baseline as the sound doesn't mess up. You definitely want as high a resolution and quality panel as you can get though - the more lines the better.
bulbousbeard
« Reply #23 on: August 19, 2014, 11:35:29 am »
The problem with syncrefresh is that anything that runs below 58hz is going to sound like this:
« Reply #24 on: August 19, 2014, 11:41:48 am »
Ok, we're all wrong, those of us who have been doing it this way for years. Let me take my 50 inch Samsung LCD TV and figure out a way to cram it into my cab so I can play Lock N' Chase in SUPAR HIGH DEF!
bulbousbeard
« Reply #25 on: August 19, 2014, 11:49:14 am »
Oh GOD. 50" TV? WOW that's a lot of input lag (and 1080p isn't enough resolution).
Calling the cabinet cops.
« Reply #26 on: August 19, 2014, 11:55:21 am »
Dude, I'm tired of you. Go wait for your G-Sync to come from Newegg and leave the rest of us fossils alone to play Pac-Man while you play Ultra Super Street Fighter IX.
keilmillerjr
  • Web Developer.
« Reply #27 on: August 19, 2014, 12:05:32 pm »
If your on a budget and don't care if it only runs an nes emulator, just get a raspberry pi. Purchasing one will be cheaper than finishing your computer build that is mediocre anyways.
cools
    • Arcade Otaku
« Reply #28 on: August 19, 2014, 12:13:03 pm »
It's not that bad. Preferable to stuttering or tearing.
dkersten
« Reply #29 on: August 19, 2014, 12:27:33 pm »
X2 made your argument a few weeks ago bulbousbeard, you and him should get together for coffee, looks like you would get along perfectly.  The FACT is, I have been gaming on LCD's for over a decade and I can assure you that it works just fine.  I am not entirely sure what your argument is now, you seem to be arguing both FOR LCD's in gaming and against them.  But here are some counters to your points:
1) V-sync doesn't cause stuttering unless your video card can't maintain 60 fps, and frankly if you are looking for perfection in a game, you will NEVER get it below 60 fps.
2) Screen tearing will only happen if your framerate drops below 60 fps, with v-sync on.
3) You are mixing up the frequency of frames from the old analogue signals with what a digital rendering will do.  Mame won't speed up the game to output 60 frames per second to achieve v-sync, the video card will just upscale the number of frames to get it above 60, just like it will do when watching a 24 fps blu ray or viewing a static picture on your screen.  It is when your video card can't process those frames to begin with that you run into problems.  Upscaling is easy, creating new unique frames is the hard part.
Personally with v-sync on I don't notice any tearing in mame.  Demul on the other hand will tear like crazy, but not enough to warrant a $700 monitor and a $300 vid card to run it, besides, I don't even notice it any more.
Screen tearing, ghosting, and latency can make an LCD perform horribly in comparison to a CRT, but with a CRT you are pretty much stopping yourself at about 20" if you want more than SVGA resolution, and I LIKE having a 24 or 27" for my PC and for modern games.  So while high res CRT's were better than LCD's 15 years ago, it is impractical and a moot point to argue the value in the comparison in regards to high end gaming.  Thing is, even in games where the graphics card can't maintain 60 fps, 99% of people will never even notice or will be used to it and not even see it happening any more.  Sure, lightboost and g-sync will each fix some problems, but you also can't run both at the same time, so either you eliminate tearing with g-sync on graphics cards that are too slow to hit a steady 60 fps, or you get better latency and less ghosting with Lightboost.  And both technologies only work on TN screens, they can't achieve the results on any IPS screen, so you have crappy colors and bad off axis viewing.
And resolution has nothing to do with it.  I run my 10 year old LCD at 1920x1200.. higher than the latest 1080 monitors.  And since it is a good TN, the latency, even at that age, is about 5ms, far faster than the QHD IPS screens.  AND at that resolution, just like in QHD (1440 lines) it takes a monster graphics card to get 60 fps in anything 3d intensive.  If you haven't figured it out yet, the key to minimizing screen tearing and giving you a better game experience is going to come down to having a monster graphics card.
That being said, your last post looks like you are arguing FOR cheap LCD's..  :dizzy:  The whole idea started with a sub $100 monitor, and the reason I pointed out a 4:3 19" is because at that price point any newer 16:9 is going to give you a smaller game field (you can find 20-22" screens at that price used).  I personally use 27" IPS panels in my cabs, but if they made a decent 4:3 even at 22-24" I would use those instead.  No way I would use a $700 monitor that requires a $300 graphics card to run mame games in a cabinet.  On my gaming computer, if I were still into FPS games, I would (and almost did) buy one.  Chances are my next gaming monitor will be a decent IPS for around $300 instead, even though I can't do Lightboost or G-Sync with it.  But my priorities changed in recent years, I care more about color and picture quality than I do about playing first person shooters.
Bottom line, anything smaller than 27" LCD for arcade I would use a 19" 4:3, it makes more sense and gives a larger play field.  Above that any decent IPS 27"+ would be just fine for me.  Trust me, an extra 10-20ms of latency or a little slight ghosting will NOT affect my pacman game.
shponglefan
« Reply #30 on: August 19, 2014, 12:47:58 pm »
Says the person who clearly did not read the OP's requirements...  ::)
nitrogen_widget
  • Last login:March 30, 2024, 09:10:09 am
« Reply #31 on: August 19, 2014, 01:13:14 pm »
I've got advancemame .106 running on a p3 1.2ghz with 512mb of ram, on-board sis video & Linux on a $20 19" 4:3 LCD I bought at the good will & i haven't had to tweak anything.
I have had to play with resolutions because i'm using a scanline generator & even though i'm tossing a low res game out to a high res monitor dig dug still looks really really good.
SavannahLion
« Reply #32 on: August 19, 2014, 01:20:25 pm »
Is driverman masquerading as someone else again? Seems like the same inane fanaticism again.
« Reply #33 on: August 19, 2014, 02:09:58 pm »
For the love of drugs, his English is too good.
TorgoHiggins
  • Showers anyone?
« Reply #34 on: August 19, 2014, 04:14:41 pm »
raspberry pi.
Snazzy! I'll definitely keep that in mind for the future. But fwiw, my computer build, such as it is, is essentially done. 8)
« Reply #35 on: August 19, 2014, 07:21:34 pm »
raspberry pi.
The Master would approve!
TorgoHiggins
  • Showers anyone?
« Reply #36 on: August 19, 2014, 09:32:09 pm »
I'm still waiting on bits to arrive, but even if everything doesn't go quite as planned, I'll have gotten away far cheaper then I would have thought.
In the meantime, a question of wood: What use? Poking around, MDF seems to be the choice. Does it fare well in humid climates? I'm a little concerned about moisture taking its toll. Is there anything I can do to protect the wood?
« Reply #37 on: August 20, 2014, 01:09:56 am »
For MDF in a humid environment, your choices are:
Seal with primer/paint or swell and rot.   >:D
(Cue the usual jokes about unprotected wood, dampness and houses of ill-repute)
bulbousbeard
« Reply #38 on: August 20, 2014, 10:31:04 am »
It's really amazing how much ---saint's minion-poo--- you managed to pack into such a short post. You managed to be wrong about essentially everything you said. Pretty impressive.
Even if you get 100% speed in MAME, if the original game didn't run at 60hz, it will stutter on a 60hz LCD. If V-Sync is on, you must be running at the game's native refresh rate for smooth video. Mortal Kombat runs at ~54.7hz, so "perfection" there is running at 54.7hz. There is nothing magical about 60hz. Most arcade games DON'T run at 60hz. You realize that there are a lot of games that run ABOVE 60hz, right? It's not possible to run these games at the correct speed on a 60hz monitor with V-Sync on. I love how you mention Pac-Man as an example of a game where this doesn't matter, but Pac-Man actually runs at 60.60hz. It's impossible to get it to run at the right speed with V-Sync on a 60hz monitor.
You don't understand how V-Sync and tearing work. Tearing primarily occurs when you're outputting frames faster than your monitor's refresh rate. By the way, V-Sync introduces at least 1 additional frame of lag universally. It's inescapable. G-Sync has less input lag. It's objectively better.
Give how close together your eyes are, I'm not even convinced you can see at 60fps.
That's some of the most ignorant ---saint's minion-poo--- I've ever read on this forum. Digital rendering? What the ---fudgesicle--- are you talking about? You realize that there are digital CRTs, right? Jesus you're clueless. You realize that 24fps movies have judder/stuttering at 60hz, right? Watch any movie with a slow panning camera. It's not smooth.
http://www.projectorcentral.com/judder_24p.htm
MAME doesn't "upscale" frames. Drawing the same frames again and throttling to make up for the fact that the game doesn't run as fast as your refresh rate is what creates the stuttering in the first place.
"Sure, lightboost and g-sync will each fix some problems, but you also can't run both at the same time"
Actually, GroovyMAME has black frame insertion, which is essentially a software implementation of what lightboost gives you, so you can have both at the same time.
Actually, both G-Sync and lightboost work on IPS panels. There is nothing about either technology that's specific to a certain type of LCD panel. Overlord Computer is working on an IPS G-Sync monitor right now. I'm curious, can you type ONE sentence that doesn't have multiple glaring loads of ---saint's minion-poo--- in it?
"And resolution has nothing to do with it."
I never said that resolution had anything to do with motion smoothness. I said that <= 1080p LCDs suck ass for arcade emulation. Nice strawman argument. Games in MAME look like ---steaming pile of meadow muffin--- without HLSL. HLSL requires 3840x2160 to be able to output an image with even scanlines and a decent shadowmask. Even 1440p is insufficient. Resolution makes a HUGE difference for quality arcade emulation.
Your whole post is a ton of misinformation, confusion about how technologies actually work, and the idea that it's foolish to spend a lot of money on a quality setup. Quality costs money, the lineage of arcades is about using the highest quality components available to create amazing game experiences, and you're completely full of ---steaming pile of meadow muffin---.
« Last Edit: August 20, 2014, 10:40:47 am by bulbousbeard »
shponglefan
« Reply #39 on: August 20, 2014, 12:00:21 pm »
Wut?
Why can't some people understand that their personal goals are not everybody's personal goals?
