Author Topic: Noob wants to build a MAME cabinet for under 200$  (Read 11011 times)
  • Last login:Yesterday at 09:39:49 pm
Re: Noob wants to build a MAME cabinet for under 200$
« Reply #80 on: September 01, 2014, 06:55:57 pm »
Sure. If you just want to be able to play classics, that's a good compromise. Keep the idea of a cabinet in the back of your mind... We'll be here to help when you're ready!  :cheers:
Plus, if I wanted to, I can replace the regular sticks with fighting sticks, right?
I think you can, but I don't have any experience with one so I don't know the process. Anyone care to weigh in?
According to Randy, the X-Arcade sticks use a Happ/Wico mounting pattern.
The OMNI2 has the larger plate that is compatible with both the HAPP/WICO/X-Arcade, etc.... patterns, as well as the narrower Sanwa, Zippyy, etc... varieties.
« Last Edit: September 01, 2014, 06:58:47 pm by PL1 »
mkwfreak
  • Last login:November 25, 2014, 08:49:59 pm
« Reply #81 on: September 01, 2014, 07:28:15 pm »
I think you can, but I don't have ]Sany experience with one so I don't know the process. Anyone care to weigh in?
so, would this work?
http://na.suzohapp.com/all_catalogs/joysticks/50-6070-160
« Reply #82 on: September 01, 2014, 08:54:34 pm »
According to Randy's post, this one by Severdhed, and the post just after it, the Happ Competition you linked should be a drop-in replacement.
There is a difference of 1.8mm on one axis and a 1mm difference on the other.
X-Arcade stick diagram
Happ Competition diagram
Worst case scenario, you might have to drill the mount holes slightly larger. . . or use a wasp rasp like GeoMan suggested in the link above. :lol
Jamesbeat
  • Last login:February 11, 2019, 06:13:39 pm
« Reply #83 on: September 03, 2014, 09:15:24 am »
I am building a cabinet, and it's going to come in at a lot less than $200.
I had already planned my build and bought joysticks and buttons when my wife lost her job.
I make decent money, but here in NY, the cost of living is so high that I couldn't spend lots of money on a cabinet without eating into my family's grocery bills.
I got sick of looking at the joysticks and buttons and not being able to afford to build a cabinet, so I resolved to make a temporary one out of whatever I could lay my hands on.
My neighbor was getting rid of an Ikea dresser, and asked if we wanted it.
I took it and stripped it down to the individual boards.
Since I only had a small amount of wood to work with, I decided to make a bartop and put it on a piece of furniture like this guy did (he used a fridge):
http://imgur.com/a/46GDP?desktop=1
Instead of springing for an ipac, I hacked a pair of $3.50 usb gamepads.
I already had a Raspberry Pi and an lcd monitor.
I had intended to use the Raspberry Pi in my planned full-size cabinet build anyway, but its small size sure came in handy when squeezing it inside a bartop.
The wood for the battens was cheap. I think it was $1.60 for an 8' length, and I used two lengths.
Screws, wood filler, paint, jigsaw blades and other sundries came to around $25 or so.
I have yet to buy a slot cutter for my router to do the T-molding, and I still have to do all the sanding, filling and painting.
I also still have to find a suitable piece of furniture to mount the cabinet on.
Once I find something that will work, I'm going to paint it to match the cabinet and add T-molding to it.
Building it this way is not only economical, it will also allow the cabinet to be taken down into two pieces if I move house.
I now have a pretty good cabinet that I can play, instead of a couple of joysticks and a bag of buttons.
I'll probably end up making a new one when I have some money, but it has certainly taken the pressure off.
When I do get around to making a new cabinet, I will have 80% of the tools and parts I will need, so I won't be buying everything from scratch.
Since I already have a perfectly serviceable cabinet, I can acquire the materials for my 'proper' build gradually, rather than trying to find all the money in one go.
EMDB
  • Project RetroCade
« Reply #84 on: September 03, 2014, 12:21:02 pm »
As we say on the forum:
Generic Eric
  • Last login:March 05, 2024, 09:02:23 am
« Reply #85 on: September 03, 2014, 12:33:35 pm »
Specifically, in your own project thread.
Jamesbeat
« Reply #86 on: September 03, 2014, 12:39:22 pm »
Sorry for the awful photos, but you get the idea.
As you can see, it's very much a work in progress.
I still have to fill in the screw holes, sand, add T-molding and paint.
I also have yet to add an amp and speakers and plexiglass.
Still, it's an arcade cabinet, and it cost practically nothing.
« Last Edit: September 03, 2014, 12:42:35 pm by Jamesbeat »
mkwfreak
« Reply #87 on: November 20, 2014, 04:05:55 pm »
Sorry for the big bump, but I wanted to explain why I got sidetracked.
My laptop died IRL, and I needed to get a replacement. My friend sold me one for cheap, but now i'm down a lot of cash, but things are looking up.
My birthday is in 6 days, and i'm going to get some cash for that, throw in x-mas and in a few months my SSI, I should be able to build it, and get a few other cool things too. And I should be able to buy high-quality parts, and be able to do this without that tiny little budget. We can still do the planning now, if you guys wish until then, but I won't make much progress until I start getting checks.
Sincerely,
     ~mkwfreak.
  • Last login:April 28, 2024, 12:59:28 pm
« Reply #88 on: November 20, 2014, 05:06:07 pm »
SSI?
  • Last login:April 27, 2024, 06:07:53 pm
« Reply #89 on: November 20, 2014, 05:14:03 pm »
JDFan
  • Last login:May 21, 2023, 04:07:42 pm
« Reply #90 on: November 20, 2014, 05:20:12 pm »
SSI?
Supplemental Security Income?
Probably his 65th Birthday in 6 days !
« Reply #91 on: November 20, 2014, 05:39:04 pm »
I thought he was turning 18?
As for a kid, I'm 17. Young, but I've been interested in electronics since I was 2-3 (playing floppy discs on windows 95), and I have learned a LOT of information over the years. And I have a step dad with a machine shop, and a computer expert for resources. I may be young, but I have a lot of faith in this.
mkwfreak
« Reply #92 on: November 20, 2014, 06:01:40 pm »
I'm have a chance of getting SSI when i turn 18 because i have autism, and possibly a few other things.
General_Faliure
  • Last login:March 01, 2022, 07:30:40 am
    • My Arcade Cab
« Reply #93 on: November 21, 2014, 07:11:31 am »
I built my cab mostly from stuff i had lying around; plywood, old computer parts, which had cost me next to nothing.
I also use Linux as os.
Plywood isn't the best choice, it's difficult to get smooth, MDF would be better.
Most expensive where the joysticks and buttons which i bought from Ebay.
See the pictures in the link below.
I am currently redoing the paint job.
I learned a lot from this build, and am planning to do a new build in the near future.
My Arcade cab: https://goo.gl/photos/yE1KACHryQjCaaCj7
Core2 duo8400 @3.6 Ghz, 4Gb of mem, Geforce 9500.
Linux Mint 17.3 XFCE, Mame, Mess, Daphne FS-Uae, Mednafen and some more.
Mah!cade
DietCoke
  • Last login:October 10, 2020, 08:32:13 pm
« Reply #94 on: November 21, 2014, 02:50:24 pm »
-self-edited-
« Last Edit: November 21, 2014, 06:44:33 pm by DietCoke »
mkwfreak
« Reply #95 on: November 25, 2014, 02:40:25 pm »
well, my birthday is tomorrow, so i hope to get some cash. I think I still have 90$ or so that I have entitled to me, so maybe I can have the funds by Christmas to get all the big things purchased, but there is one little thing that scares me. I've had more than a few scares with ESD, and I'm scared with the I-Pac and wiring, because most if not all of my place is carpeted, and I barely have enough space in my room to fit something like an arcade cabinet. Any advice?
« Reply #96 on: November 25, 2014, 02:41:46 pm »
Buy a Tankstick?
mkwfreak
« Reply #97 on: November 25, 2014, 02:48:55 pm »
Well, I guess I'm gonna get a tankstick then. Kind of wanted to get a custom control panel, but I guess this is the best way. I suppose I can think about that in the future.
dkstanson
  • Last login:December 03, 2014, 07:44:25 pm
« Reply #98 on: November 28, 2014, 07:51:43 pm »
well, what part of the country are you in? Lots of us have heaps of spare parts we could give you.
"Engineering is the art of planning and forethought | iPhone music transfer tutorial "
