Author Topic: Metal Control Panel Stripping  (Read 1074 times)
Opie
  • Newbie
  • Last login:September 02, 2014, 10:00:33 pm
« on: August 05, 2014, 09:29:56 pm »
I have a metal control panel. It has a lot of scratches and I want to paint it a different color. It still has the original art on it. I know I can the art off with a heat gun from reading the forums. I was wondering if anyone had any solid advice on how to strip it down so I can repaint it. Some options I've read are paying someone to sandblast it, citristrip or just using a sander. Any information will be grateful. Thanks guys
« Last Edit: August 05, 2014, 09:46:05 pm by Opie »
eds1275
  • Last login:May 03, 2024, 12:05:34 pm
  • Rock and Roll!
Re: Metal Control Panel Stripping
« Reply #1 on: August 06, 2014, 11:15:18 am »
You can buy paint and finish strippers in the paint section of any store. One time I took the finish off of a piano with a chemical, it was actually fast and awesome.
Well Fed Games
  • Last login:March 06, 2022, 07:30:46 pm
  • Delicious!
« Reply #2 on: August 06, 2014, 11:59:10 am »
Yeah, chemicals work well, I've had luck with Citristrip for sure. My current method pretty much consists of heat (from a grill or heat gun), metal scraper for the vinyl/thick adhesive, and a random-orbit sander with 80-grit discs to get it to bare metal.
dkersten
« Reply #3 on: August 06, 2014, 03:41:51 pm »
The advantage of using a power sander is if there are any scratches that scored the metal, sanding it can smooth those out where stripping it is still going to leave them there.  Just wear protection whatever you do - if you sand, the paint might have lead in it and when you turn it into dust that can be really bad.  If you strip, usually the chemicals are not good for your skin, and can have toxic fumes (and again if there is lead in the paint it can harm you).
  • Last login:October 20, 2023, 11:39:06 pm
« Reply #4 on: August 07, 2014, 11:02:41 pm »
I remove the sticker with a heat gun.  Then I just use this to remove the sticky leftover crap and the rust.  $5 at Home Depot:  http://www.homedepot.com/p/Avanti-Pro-3-in-Wire-Cup-Brush-PWW030CUPD01G/202831066
DeLuSioNaL29
Yinzer
  • Last login:October 23, 2019, 09:54:32 pm
« Reply #5 on: August 07, 2014, 11:06:17 pm »
Chemicals and metal scrapper.
