Main > Project Announcements
Space Base - A homebrew ICB/ZP
Pages: << < (30/51) > >>
yotsuya:
--- Quote from: Vigo on January 16, 2015, 03:07:25 pm ---
The SNL commercial this GIF comes from is an all-time classic....
Nephasth:
For years I've wanted an ICB. But then I played one for the first time recently. Definitely dig this project though. Love the mechanical nature of the machine. :cheers:
wp34:
That engraving on the bottom is off the hook.   :applaud:
Can you give some more information on how you did that?
Le Chuck:
Thanks for the kudos guys!  It's coming along, I went to see American Sniper with a buddy (OMHFG that movie was intense - definitely hit a few nerves) and when I popped the garage door up I was so happy to see this build sitting there in the middle of the garage.  No where near complete but I've been working on this for god, almost two years in some form or fashion.  Really nice to see it starting to come alive.
Any opinions on skinning the sides?  MDF for a black paint job (body panels will be black) or a nice wood panel and stain?  I'm leaning towards stain as homage to the inspiration machines.
--- Quote from: wp34 on January 16, 2015, 07:35:24 pm ---That engraving on the bottom is off the hook.   :applaud:
Sure, to start it's machine cut, wish I could do that by hand - there are some contraptions out there with which you can but I've never used them.  The cam software I'm using is called ArtCam.  It's not great by autocad standards but it really blurs the line between cad software and image manipulation software so it's easy for me to use being a photoshop guy.  It's able to take all the installed system fonts right into vector (unsure if all cad software does this, assume they do) and after that I just cut it apart and add some more lines to give it the look I want, same as you manipulate a font in photoshop.  Kearning, line spacing, ratios all adjustable.  I set the program to use a 1/4" 60o V bit and cut to a depth of .1" on the outside of my vectors.  The settings for that bit have it making four passes to get to full depth at a cut rate of 30 inches per minute.  This gives a super clean edge.  For comparison the panels were cut in two passes at 100 ipm so it's a big slow down.
Having a CNC machine available completely spoils one, at least it has spoiled me.  I dread cutting things by hand now because, even tho I have good saw boards and can cut a clean line, there is something wonderful about those perfectly machined lines.  I still love my sculptural work but when I'm trying to be exact, well, nothing beats the exactness of that CNC machine.  Plus, it was really something to draw it all out before hand.  I never do that, I just get two or three key measurements in my mind and head out to the garage and build around those.  My builds kinda grow.  This needed to be spot on and it's very important to me that when it is done I can publish cut plans.  Just a different process, its new to me and I'm excited about it.
--- Quote from: Nephasth on January 16, 2015, 07:29:35 pm ---For years I've wanted an ICB. But then I played one for the first time recently. Definitely dig this project though. Love the mechanical nature of the machine. :cheers:
Heh, I've heard something to that effect from a few people.  I can't wait till it's playable, and I think Space Base has a few features that will really improve some aspects of gameplay over ICB, but at it's heart it's still a bar and ball game.  This is such a labor of love for me it's all about the process for now.
wp34:
Thanks for the detail on how you did the engraving.  I've looked at those rigs that let you copy an image with a router but I can't imagine it would look nearly as nice as what you get with a CNC.
--- Quote from: Le Chuck on January 16, 2015, 08:21:03 pm ---
If you were serious you would hand scribe a small pattern over and over and over again into the sides using a dremel tool.   ;D
Go to full version
