Main > Software Forum
Arcade Jukebox 6
random24:
:o I think I may have found another bug. I thought that with the last version if you exited the app it would reset your resolution back, but with this one I can only see about 1/4 of my desktop when I esc. My default res is 1024x768 and my OS is WIN2K. I definitely like the program. Keep up the great work.
Howard_Casto:
An update on the not being able to use the frame key bug...... Now it lets you use the frame key (left shift by default) but it won't let you re-define keys... no matter what i assign it to only left shift will work as the frame key.
Howard_Casto:
Also on my machine every time you use the option to scan local harddrives it still crashes?
Keep up the good work,
HAC
drabbit:
The newest release will not even play the mp3, the selected title will briefly flash in the now playing window and disapear without even playing it!
Dr. Jay:
I'm having a few of the same problems mentioned by others here.
1. My screen also doesn't resize if I exit using escape, but it does with the configurable exit. I'm running Win98SE.
2. I'm not getting the frame key to work at all.
3. The mp3's quickly display in the queued list, jump to the currently playing list, and then shuts off. The mp3 never get's played.
So, I'm still using your earlier release of Arcade Jukebox 6 without the frame key and using "Q" to quit. I absolutely love the program though, and thanks so much for getting rid of the mouse options when in vend mode. -Dr. J
And I also think the new arcade jukebox logo on the side is cool. It gives it a nice touch.
