Author Topic: Arcade cabinet PC question  (Read 1228 times)
Petey09
  • Last login:November 13, 2014, 08:39:27 pm
« on: July 29, 2014, 10:16:27 pm »
(Sorry in advance for my poor english)
Hey guys,
First time posting but I've been snooping around for a while now. I've contemplated the idea of building my own arcade for a while now and decided to pull the trigger recently. I have a friend helping me with woodworking stuff so I should be good on that front. But for the inside, I have too many questions to count but I guess I'll the answers I need as I go.
But still, before destroying stuff I put money into I would like to make sure that I won't break them while installing or modifying them. So here are two little questions :
1 - I decided not to not use a case for the PC components (motherboard and all) and directly mount it inside the cabinet. Should I mount the motherboard on something special (metal plate) or simply screw it directly on the case?
2 - I have a LCD screen laying around that I plan to use. Is it safe to remove the bezel to save some depth space?
Thanks in advance!
SpatzST
  • Last login:April 18, 2021, 05:29:46 pm
Re: Arcade cabinet PC question
« Reply #1 on: July 30, 2014, 12:11:28 am »
Not sure about the LCD, but for the motherboard, I think you just need to put a spacer inbetween the motherboard and your cabinet...
EMDB
  • Project RetroCade
« Reply #2 on: July 30, 2014, 03:45:56 am »
For mounting the motherboard just use feet like these:
« Last Edit: July 30, 2014, 03:48:13 am by EMDB »
Petey09
« Reply #3 on: July 31, 2014, 12:19:19 pm »
Thanks guys. That's exactly what I needed!
BobA
  • What Me Worry?
« Reply #4 on: July 31, 2014, 04:35:32 pm »
If you do not want to order PCB feet just use a cut piece of BIC pen and a longer screw to hold the piece of pen between the mount and the pcb.
  • Last login:Today at 12:55:42 am
« Reply #5 on: July 31, 2014, 05:47:12 pm »
You can also use 1/4" PEX pipe.
Slippyblade
  • Last login:November 16, 2023, 11:39:51 am
« Reply #6 on: July 31, 2014, 05:54:09 pm »
I like to gut the mounting tray out of the PC case.  I just bandsaw the tray out of the case, then screw the tray to the wood and use the normal mounting for the motherboard.
